1991 FXSTS Pinion Gear Nightmare
Old Jan 7, 2025 | 03:24 AM
Cockle's Avatar
Cockle
Default 1991 FXSTS Pinion Gear Nightmare
Good morning one and all, I trust you're well.
So I'm having an issue getting right with selecting and finding the correct pinion gear for my 1991 FXSTS. After a lot of research and learning a few new things I am coming up blank with what I'm looking for.
The main issue it seems is that the 90-92 softail was a "crossover" period between the earlier 89's that had a tapered shaft with a recessed gear for the nut, to the 93's and later that have no taper on the shaft
and no recess in the gear.
I cant find anywhere that has the pinion gear I need. What I'm wondering is, am I missing anything thechnically? If I cant find the OEM part #24043-90, what other options do you think I might have?
Huge thanks for any thoughts offered.
Old Jan 7, 2025 | 04:43 AM
Jackie Paper's Avatar
Jackie Paper
See the item here and numerous other sales..
Did no research. Just part number. Not sure that helps you.
https://www.ebay.com/itm/27676554392...mis&media=COPY
Old Jan 7, 2025 | 05:08 AM
Cockle's Avatar
Cockle
Thank you so so much Jackie, that item was coming up for me, even though I had selected international. very strange but thanks again :-)
Dudlybooth
Mar 9, 2024 11:28 AM
VortecCPI
2014-2024 Touring Models
20
Sep 30, 2023 02:06 PM
FLshovelhead
Shovelhead
25
Nov 30, 2021 03:29 PM
twistr
Dec 18, 2012 07:41 AM
StuxnetKiller
EVO
Sep 12, 2012 03:27 AM
