A 2004 CVO deuce uses a 3/4" front axle. Softails didn't even use a 1" front axle. They changed the front from 3/4" to 25mm in 2007 ... The Rear in 2008
Why can't people check their facts before posting? ... just look at the parts diagram/list
I looked online it said it went to 1 inch then I seen the parts catalog and it said 25mm either way I was trying to see if I can make it work but as I'm seeing here I can't it sucks I really like that wheel
If you have a 25mm/1" front "Detonator"wheel that was offered through Harley's "Parts and Accessories" (in approx 2007) ... then USE IT
If you have a 3/4" ONLY front "Detonator"wheel that was offered through Harley's "Parts and Accessories" (before 2007) OR was an Original Equipment wheel from a 2004 FXSTDSE ... then BORE IT
