Spring maintenances
Old Mar 7, 2025 | 06:28 AM
702's Avatar
702
I have attached the Harley maintenance table for you. Go to the Softail section and start checking off the items as you have time and you'll be ready for your riding season when it comes.
File Type: pdf
Old Mar 7, 2025 | 07:46 AM
mpaquette's Avatar
mpaquette
Go Habs Go!
Old Mar 7, 2025 | 08:24 AM
hattitude's Avatar
hattitude
Originally Posted by Jackie Paper
It's just eye candy now. Probably the o-ring. Does have 50k on it.
That would drive me & my OCD nuts.. even if it's hardly ever ridden...
If you find me in your garage some morning working on your bike, it's because I couldn't sleep thinking about it....
Old Mar 7, 2025 | 09:21 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
At my age, OCD is long gone
Old Mar 7, 2025 | 11:29 AM
H41's Avatar
H41
Thanks I’ll take a look at it. Dont want to become mecanic but good to confirm things.
Old Mar 7, 2025 | 05:27 PM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Now that there made me laugh out loud, and the wife wondered what was wrong with me.... Mr. H, hats off.
Old Mar 7, 2025 | 06:46 PM
Jackie Paper
You didn't mention previous or even up to date maintenance. However ever couple years, it's a good idea on car and bikes to remove the brake fluid down in the masters and refill with DOT 3 or 4. (Not to low) Then vacuum them at the caliper refilling the master a couple times. (Cover loose)
The system is a totaly sealed system and has the level button on the cover but opening the cover leaves a tad of moist air on top.
That should never be bad enough to actually have air in the line that's not absorbed by the DOT 3.
The air is on the top side of the cover bellow gasket. Before to collapse bellow when done.
As pads wear, pistons stay out, so fluid level does need to be monitored regularly. Shine a light on cover button. It will look clear if fluid is too low.
Don't overtighten cover.
Old Mar 8, 2025 | 09:53 AM
Willburrrr2003's Avatar
Willburrrr2003
Hope the salt dust is off the road
Yes that is important aside from the salt corrosion aspect of it, as it piles up in unexpected places and can surprise you in corners.
Cootey
2018+ Softail Models
May 14, 2024 06:21 PM
GOGOBECK
Mar 17, 2024 09:45 AM
slow96z
Feb 20, 2024 08:45 AM
05flhtbob
Great Lakes
15
Apr 24, 2023 06:27 AM
Casper
Apr 9, 2009 01:29 PM
