2009 Deluxe
Old Jul 18, 2025 | 11:13 PM
BigVtwin2000's Avatar
BigVtwin2000
Stage II
Default 2009 Deluxe
Changed fuel pump as all the lines were rotted. Literally just fell apart in the tank.
However it still does not start.
I have checked that it does indeed pump, pulled the injectors and tested and they are fine.
I’m hearing a little motor sound and a light tapping noise coming from the throttle body area and can not seem to pin point it. Anyone know what this might be?
Thanks in advance
Old Jul 18, 2025 | 11:33 PM
Roberto88's Avatar
Roberto88
Check the idle air control valve (IACV) near the throttle body it might be the source of the motor and tapping sounds. Also, verify the fuel pressure regulator and ensure the ECU isn’t throwing any codes. If all else fails, inspect the throttle position sensor (TPS) or wiring issues in that area.
Old Jul 19, 2025 | 06:08 AM
Jag Jim's Avatar
Jag Jim
Maybe this may help. It's a different bike but parts should be close.
Old Jul 19, 2025 | 03:00 PM
BigVtwin2000
Stage II
Thanks, I believe it’s the IAC valve. Ordered one and will be here Tuesday.
Thanks a lot!!
phillips
Feb 23, 2022 02:28 PM
jp2code
Jul 3, 2020 02:32 PM
neocacher
Mar 30, 2017 11:22 AM
4x4Given
Motorcycles For Sale
Jun 26, 2010 11:19 PM
TurboExempt
Jun 25, 2009 02:41 PM
