Ironheads had them and woe betide anybody foolish enough to remove one....VERY fine threads that usually came out with the plug!
I believe Pre-1977 Yes.. And also Yes...Very Bad idea to remove it.. Guaranteed to leak foreverafter!
I have never seen any reason to purge a bottom end...Unless it really should have come Apart. But, if I felt the need...I would do the "waste a quart" method...run clean oil in, till clean oil comes out!! A waste IMHO
Welp...I can see some Draining going on... a Useful Tool BTW in Racing so one can see about how much oil to By-Pass!!
Gotta chop the throttle tho... like for Plug Reading...But, Not the preferred "Shut-Down Method" on strip..
