2018+ Softail Models Breakout
Baffle removal
Old Jun 18, 2026 | 07:53 PM
Strangewayz's Avatar
Strangewayz
Stage I
Default Baffle removal
I have a Street Bob 2025 I removed the baffles is it good to take out the cat also and put the thunderstorm inserts in anyone have an opinion about this I already took the baffles out and I noticed a little bit of difference and running a little hotter
Old Jun 18, 2026 | 09:15 PM
CoolBreeze3646's Avatar
CoolBreeze3646
My Opinon:
It is running hotter because it is running leaner with the baffles removed.
Do the right thing and get a good set of slip-on mufflers and a tune if you want a louder bike. Removing the Cat will not make much difference unless you put a free flow air filter on and a tune.
Some things should be left alone unless you really know what your are doing. Your engine will suffer and you will have a decrease in power.
Make sure you wear ear protection otherwise your hearing will suffer in your right ear.
NOTE:
The above information, while credible, is worth what you paid for it and should not be considered gospel.
Do due diligence, research and have a H-D Field Service Manual before working on your bike.
You will probably have many opinions and suggestions presented; make sure you research the person providing the helpful information as there are some who provide good information that is useful and some who speak out of other orifices with gibberish. You will figure out this quickly.
Old Jun 18, 2026 | 11:55 PM
bustergut's Avatar
bustergut
You might get more/better answers at the 2018+ Softail M8 forum
https://www.hdforums.com/forum/2018-softail-models-206/
(a sub-forum of this 2000-2017 Softail TwinCam forum)
Old Jun 19, 2026 | 05:46 AM
Jackie Paper's Avatar
Jackie Paper
If you must do that, do it right with a factory designed system and a tuner.
@Strangewayz
Welcome to the HDFORUM. Hold up on starting another thread on same topic. Community team will move it for you.
@2goldens or @foxtrapper Would you slide this over to the 2018 Section if you think it's better there.
Old Jun 19, 2026 | 08:49 AM
Powermankw's Avatar
Powermankw
Removing the baffles is not recommended... And no, you don't need a tune for it. I did it, didn't care for sound really, and it was a hit to performance.
First... Removing cat will do nothing. Cats just are not restrictive. They flow really well.
Second, I assume you mean thunder torque inserts... Lollipops. DK customs... Dumb name. But yes, those are absolutely beneficial. You just gave yourself reversion removing the baffles, and lolipops will correct that.
Once you do that, you will get a performance boost. The baffles are indeed super restrictive. The M8s are really strangled from factory. Air cleaner and slipons, or removing baffles... Gets them breathing better.
You don't need a tune for baffles... Or slip ons which is what you did. You need a tune just because it's better overall, but the computer has plenty of room to correct for a bit more air. When I removed mine, it was always temporary cause I knew I would be putting pipes on. But for you, if this is permanent... Well ya, you really should just get a slip on because the sound will be tuned better... And you shouldn't have reversion... But I suppose that is still possible, and lollipops will still help that.
South Jersey Scooter Trash
May 10, 2013 05:32 PM
azbob09
Jan 18, 2013 05:13 PM
apxpred
Oct 28, 2011 11:28 AM
Matt0987
Aug 29, 2011 07:24 PM
Thunderheader
May 14, 2010 07:25 PM
