NE1 ever poked a hole in their oil filter ??
Old Sep 20, 2007 | 10:10 PM
HarleyWood's Avatar
HarleyWood
Default RE: NE1 ever poked a hole in their oil filter ??
for all the trouble trying not to spill a little oil, its just not worth it to me,
I set an old aluminum baking pan under the frame and unscrew the filter and let it drain, wipe up the little bit of mess with a paper towel.
a couple of squirts from a spray bottle with dawn dishwashing liquid to get the hard to reach spots and done.
Old Sep 21, 2007 | 05:45 AM
wingnutt's Avatar
wingnutt
ORIGINAL: craig06flstci
Forget the Coke bottle. Get a roll of foil out of the kitchen, double up a piece about 16"long, stick it under the filter and adjust the edges to make a flat "trough" into your drain pan. No muss, no fuss and no tricky manuevers. Also buy K&N filters, they have a 17MM nut on the end so you can avoid using standard oil filter wrenches.
I also use the foil method, works well for me.
paulhog
Mar 18, 2012 08:56 PM
maintainin
Screamin Eagle CVO Models
Mar 17, 2009 07:34 AM
sundancewind
Oil Archive (no new posts)
Aug 2, 2008 11:22 PM
Hamperdiver
Oct 22, 2007 11:53 PM
Bubba Zanetti
Apr 13, 2007 02:15 AM
