Wheel wobble
Old Sep 29, 2007 | 10:16 AM
CaptainCanada's Avatar
CaptainCanada
2nd Gear
Default Wheel wobble
Hi,
When my Deuce is travelling between 35-50 miles per hours, I get a front wheel shimmering. It doesn't do this below 35 or above 50. Anyone have any thoughts on what might be causing this problem?
Brian
Old Sep 29, 2007 | 10:50 AM
06Fatty's Avatar
06Fatty
Default RE: Wheel wobble
Have you checked air pressure?
Old Sep 29, 2007 | 02:37 PM
CaptainCanada
2nd Gear
Yes, the pressure is fine.
Brian
Old Sep 29, 2007 | 02:56 PM
tunaman's Avatar
tunaman
https://www.hdforums.com/searchpro.a...bmitbutton=+OK+
Glad to be of assistance...
Old Sep 29, 2007 | 03:14 PM
PoorBoy's Avatar
PoorBoy
I wish I could remember which tech on here had that problem nailed-down. I can't find the original thread now. Bookmarked at work, so I'll add it on Monday.
If you are noticing the wheelwobble during slow-down, most likely at (or real near) 40mph, then have your tensioner checked in your primary. The chain insideis too loose. You are feeling torque-play that manifests itself out to your front wheel.
It may sound odd, but if you have a relatively new bike, maybe less than 5,000 miles, I'd have a Harley tech check it for you. It is an easy adjustment for them, and should be checked at the 5k service.
Old Oct 1, 2007 | 05:35 PM
SFarace20's Avatar
SFarace20
I had the same thing on my '03 Heritage and found that the bolt that holds the neck tight was loose, I tightened it up and no more issue!
thephantomsfire
Jun 13, 2012 01:40 PM
2black1s
Mar 27, 2011 08:42 PM
jrjones
Harley Davidson Videos
Nov 29, 2010 06:01 PM
Gabriel
Jan 27, 2009 07:03 PM
dklozik
Feb 13, 2008 07:51 PM
