Trailering Tie Downs
Old Oct 15, 2007 | 06:01 PM
rsavage's Avatar
rsavage
Default Trailering Tie Downs
I just bought an enclosed trailer to haul my Deluxe to Daytona and the Keys from Western NY in Feb. I installed front and rear pairs of D rings and a front wheel chock. Where on the bike do folks generally hook the tie downs to? I can hook the front straps to the cross piece between the frame down tubes near the bottom of the tank ( I think where the top of a crash bar would bolt). Of course when you tighten down the ratchets, you are compressing the front suspension. Where is a good/safe spot on the rear of the bike? Bottom of rear swing arm? I have to go 1500 miles and want to get it there and back without a scratch. I'd appreciate any info based on your experience
Old Oct 15, 2007 | 06:46 PM
bensonjv's Avatar
bensonjv
Default RE: Trailering Tie Downs
First, Kudos for admitting your trailering your bike to Daytona. Few would admit the faux pas with such honesty.
For tie downs in my trailer I do the following:
Pingel chock for the front wheel. Ratchet tie downs on the handlebars. Use a couple of the tie down slings (pictured) on the bars and connect the ratcheting tie downs to them. Alternate tightening down each side until you have compressed the forks almost all the way. For the rear, definitely use something or the *** end of the bike will dance around inside your trailer. Use two racheting straps and loop through the tire from both sides and secure. The back does not have to be super tight, just snug enough that things won't come loose. You can try to find somepace on the swingarm to connect to but after trial and error I found there was no easy place to connect to without having parts get in the way (i.e. mufflers, brake, etc).
[IMG]local://upfiles/5927/52A0E66E0E724A459C917D46708A18FA.jpg[/IMG]
Old Oct 15, 2007 | 06:56 PM
rsavage's Avatar
rsavage
Thanks. BTW, I live 20 miles east of Buffalo. In February and March we ride snowmobiles. Bikes don't do well in the salt, ice and slush. Lots of pressure on the bars. I worry about them bending?
Old Oct 15, 2007 | 07:06 PM
agapsdiver's Avatar
agapsdiver
On the bars.. you use the tie straps at the bottom, on either side of the handlebar clamp...the handlebars can handle it.
Old Oct 15, 2007 | 07:11 PM
shooter64's Avatar
shooter64
Former Sponsor
use Big Daddy power ties, that is the ONLY thing we use, ask Bryan TTM or some of the other, built in fur covered soft ties, and real rachet strap, we sell them for 45.00 bucks a pair, and they are worth every penny, dont use anything else, I have tried them all belive me.
Old Oct 15, 2007 | 08:03 PM
bensonjv's Avatar
bensonjv
What he said...
ORIGINAL: agapsdiver
Old Oct 15, 2007 | 08:12 PM
DR.Greenthumb's Avatar
DR.Greenthumb
I do just as bensonjv said.Make sure the front straps are pulling the bike into the chock.I was able to use a D ring and a strap thru my pulley for a rear tie down.
Old Oct 15, 2007 | 09:24 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
rsavage,
I live over in Greece so I know what you mean about salt, snow, and ice. Its not much fun on two wheels.
Maybe I'm a little wrong, but the only time I tied my bike down on a borrowed trailer I used the same kind of loops bensonjv posted. But I didn't like the idea of putting them anywhere on the handlebars. So I looped them around the fork leg just above the lower tripple tree. The fork tube and tree is more than strong enough to handleany loading you can manage to put on it with even the strongest ratchet strap.
Old Oct 16, 2007 | 08:49 AM
Mikey 1450's Avatar
Mikey 1450
Your bike, (Deluxe)has risers, Igo aroung the lower tree(around the fork tubes just below your headlight)with the straps, especially hauling it that distance. You could go to the handlebars, but 1 goodlarge bump and it could snap thebolts in the rises,Once in Daytona, you won't need the trailer.
Old Oct 16, 2007 | 09:48 AM
FastHarley's Avatar
FastHarley
Former Sponsor
ORIGINAL: Mikey 1450
Agree 100% I haul to shows all over the country and would not tie off any other place. Now for the rub. I double up the fronts. I use 6 points. [ol][*]2) on the lower trees (if you can get to them) X 2[*]1) on each side of the rear shock area or around the top shock mount if you can see it.[*]1) wraped around the rear wheel so it can not slide sideways[*]1) over the top and around the area where the seat use to be (remove seat). back down (each bike)[/ol]I use loops as per other peoples post. The additional lower trees can be mounted in a different mounting point and are redundant.
