96 Inch Conversion
Old Nov 1, 2007 | 09:24 AM
wadejesu's Avatar
wadejesu
Default 96 Inch Conversion
Does anybody know if the 07 96 inch jugs and pistons will fit an 05 88inch?
Old Nov 1, 2007 | 09:44 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: 96 Inch Conversion
If I understand the way they upped the displacement properly the jugs are the same and have the same bore size.
They basically "stroked" the 88 inch motor with a newcrank, rods, and pistons.
There are lots of other little changes inside, but that was the one that upped the size.
Old Nov 1, 2007 | 04:56 PM
rockerhead's Avatar
rockerhead
Roger That! the MOCO stroked it
Old Nov 1, 2007 | 05:15 PM
MarAgt's Avatar
MarAgt
Banned Camp
Grab yourself one of the big accessory catalogs. They have the Stage II kit which will take an 88" to a 95".
Old Nov 1, 2007 | 05:20 PM
Frisco Mesa's Avatar
Frisco Mesa
The 95" motor is a big bore which will bring you more top end(and some more low end), the stroked 96" engine will bring you much more torque!!!
Old Nov 1, 2007 | 07:18 PM
hdpearson13's Avatar
hdpearson13
they will fit there exactly the same. Now if you want a bigger displacement i highly suggest yu by this book it will help you save thosands and give you real performance that will smoke the 103 SE street legal
http://www.amazon.com/Harley-Davidso...668&sr=8-1
Old Nov 1, 2007 | 07:22 PM
99embrey's Avatar
99embrey
you can use the jugs, but they are the same, so you wont be gaining anything. you can't use the pistons though, because the wristpins are mounted higher up in the piston to keep the piston from ramming the head because of the longer stroke.
Hippiebeads
Oct 3, 2010 09:50 PM
dblkick
Sep 23, 2010 08:05 PM
tommyj
Apr 25, 2009 04:16 AM
pear69
Exhaust System Topics
Apr 7, 2008 12:41 AM
Wild1Poet2
Aug 21, 2006 12:46 AM
