Dented Fork
Old Nov 22, 2007 | 07:51 AM
Bogeyman's Avatar
Bogeyman
Default Dented Fork
Anyone know of an easy way to fix this? I tried to take apart the housing around the headlight to get to it but what I thought was some sort of cover apears to be a permanent part of the front forks...
Old Nov 22, 2007 | 07:54 AM
Texas Fat Boy's Avatar
Texas Fat Boy
Default RE: Dented Fork
Here let me help out.
Old Nov 22, 2007 | 07:55 AM
Bogeyman's Avatar
Bogeyman
Thanks, I've been sitting here wrestling with the img tag...
Old Nov 22, 2007 | 07:58 AM
Texas Fat Boy
Bogey Man, here's how you do that picture imbed:
At the start and end of your picture code change the letter "IMG" with "image"
replace the [IMG] with [IMG]
and at the endreplace [/IMG]with [/IMG]
Old Nov 22, 2007 | 08:42 AM
Bogeyman's Avatar
Bogeyman
ahhh.....easy enough.... thanks!
Old Nov 22, 2007 | 03:50 PM
powdercoater's Avatar
powdercoater
Bogeyman - That part is called many different names like fork can, cowbell or upper fork cover. It is bolted to the lower triple tree by two bolts, but you have to remove the fork tube to get it off. That means removing the tire, fender andbrake caliper.Then remove the tin piece that spands between the 2 triple trees closest to the gas tank on that side. Once those are out of the way remove the pinch bolts on both triple trees that hold the fork tube and slide the fork tube out. You may have spread the triple tree pinch area slightly to get the fork tube out. Now you can get to the two bolts that hold the fork can. Reverse for reassembly being careful to correctly torque all bolts and axle nut, and use blue locktight on everything.
Old Nov 22, 2007 | 03:55 PM
powdercoater
Just so there's no confusion, you will be able to get to the two bolts that hold the fork can without removing the fork tube but the fork can won't slide over the lower fork leg.
Old Nov 23, 2007 | 12:04 PM
Bogeyman's Avatar
Bogeyman
If I can get to the bolts and slide it down, I wonder if there is enough clearance from the top to get into it and push the dent out with something??
Seems like a ton of grief just to pull out that little dent or replace the can....
Old Nov 24, 2007 | 06:19 AM
powdercoater
You can try it, but I doubt you'll have enough room. Besides, if you pry against the fork tube to push out the dent and damge the tube it'll cost ya A LOT more money and grief than just removong the tube to start with.
Good luck!
slvrscoobie
Stock Harley Take Offs
Jun 6, 2017 06:00 PM
TattooBill
Feb 22, 2016 06:08 AM
jackietan
General Topics/Tech Tips
19
May 21, 2009 05:25 AM
Vatorman
The General Motorcycle Forum
52
Mar 21, 2009 07:13 PM
ChiefGator
May 6, 2008 02:46 PM
