turn signal problems
Old Dec 1, 2007 | 10:31 PM
forever 2 wheels's Avatar
forever 2 wheels
Default turn signal problems
My 1995 Nostalgia has attitude. The turn signals only work when they want. Both front and rear work when they decide to operate and the green light in the dash flashes. It's just that sometimes the left only works or the right only works or they both work or they both do not work. checked the connections and they seem fine. Also they only flash 8 or 9 times before turning off. I like to signal early. Anyone had this problem and found a cure?
[IMG]local://upfiles/46904/5DF75709B17A43F39EB51C923149CD83.jpg[/IMG]
Old Dec 2, 2007 | 06:34 PM
vicks96's Avatar
vicks96
Default RE: turn signal problems
On my 07 Deuce they started coming on by themselves and would not turn off or would turn on and not cut off or whatever they wanted to do. I pulled the bulbs till I got it to the shop and the turn signal module was bad. Dealer replaced it and its worked fine so far. Knock on wood!!!!!!!
Old Dec 3, 2007 | 08:48 PM
forever 2 wheels
Thank's, I think I should find a used on and see if that does the trick. I have checked everything other than that.
[IMG]local://upfiles/46904/1291CDE155CB498B8A20AC600D2E83BE.jpg[/IMG]
Old Dec 3, 2007 | 11:22 PM
ChromeJunkie's Avatar
ChromeJunkie
It mayjust need some freshblinker fluid.They say it goes bad after about 10 years and needs to be changed.
JTurner93
Apr 21, 2019 06:44 PM
hdjoe79
Aug 30, 2015 02:12 AM
the reverend
Aug 29, 2010 07:29 PM
Iamopie2FLHRC
Dec 19, 2008 11:28 AM
sr71gn
Jul 12, 2008 04:09 PM
