1st impressions-new cams
Old Dec 26, 2007 | 12:59 PM
George C's Avatar
George C
Default RE: 1st impressions-new cams
ORIGINAL: Marsh
Didn't mean to offend you 95 inchers.
You're not offending anybody.
I'm just trying to correct some bad information/assumptions you were told about bumping your cubes up to 95"
The old addage, "no replacement for displacement" is what I'm trying to tell you.
Cams are only going to helpdevelop the powerband usingthe air/fuel combustion stroke. Add more compressed air/fuel through larger cubic inches, and you willhave more to develop.
Old Dec 26, 2007 | 01:44 PM
back again's Avatar
back again
I did the same thing as you Marsh cams only without the pistons and was happy. Did the heads and 95" later and could have kicked myself for not doing it all at first. If you ride the mountians at all you will really appreciate the difference the inches add. Think my #'s with cams and cert with the rb 2-1 were83hp/87.8tq. with pistons and head work were92.8hp/100.2tq. 13lbs of tq. makes a big difference. Also noticed the change in the pipes,alot louder. Personally I like the sound of the gears crusing down the road.
Old Dec 26, 2007 | 08:18 PM
grumpy irish again's Avatar
grumpy irish again
95 without the cams will give you less than 88 with the cams
and both will do better with ported heads...
510ss cams here will do the 95 thing someday maybe...
Old Dec 26, 2007 | 08:49 PM
Skulmn's Avatar
Skulmn
ORIGINAL: Marsh
That's what she said.
What's up Marsh??????????????????
Old Dec 26, 2007 | 09:31 PM
reckless's Avatar
reckless
GEORGE C CHECK OUT THE QUICK BUMP KITS BY KURYAKEN THEY PACK MORE POWER THAN THE BIG BORE FOR LESS CASH THEY HAVE DYNO NUMBERS. BUT I BELIEVE IF YOU LIKE IT THATS ALL THAT MATTERS OR WE WOULD ALL BE RIDING THE SAME BIKE
Old Dec 26, 2007 | 11:33 PM
nikonf8's Avatar
nikonf8
big bore and heads and then you have something. a total world of difference
Old Dec 27, 2007 | 12:45 AM
Marsh's Avatar
Marsh
I'm sure big bore AND heads would be a big boast, but at what cost. I may do it later.
Hey skulman. You ridin?
No-Rice
Marsh
Old Dec 27, 2007 | 07:09 AM
George C's Avatar
George C
ORIGINAL: reckless
Cams, air cleanerand a White Bros pipe. Maybe you didn't notice in the small print where they had the heads off and replaced the head gaskets with .030 to set the squish.... That alsobumpscompression a few points.
The problem is that all of their increases are made above 3,000 RPM. It makes very little torque down low where 99% of us use it the most..
Add displacement and you get more thumping right off of idle..
Heck, they're (Kuryakyn) into the heads, so you've already paid for most of the labor to drop in the BB kit..
Do what I did. You don't have to buy the "kit"..
If you have your engine apart, just send the cylinders out for boring. Pistons and boring together will probably run about $400.00-$500.00 range. Then you can do what ever else you can afford at that point.
That's a big jump for little cash.
Old Dec 28, 2007 | 07:59 AM
back again's Avatar
back again
ORIGINAL: Marsh
No-Rice
Marsh
It was 1500 to do my heads and him cutting my jugs at the indy I go to. That was with KB's. I run 10.25 on pump gas with zero problems in 18,000+ miles.
Old Dec 28, 2007 | 08:49 AM
Live2Ride's Avatar
Live2Ride
Banned Camp
Marsh,
Glad you like your setup. Sounds awesome. Your bike just keeps gettin' better and better.
I'm gonna have to do some motor work to mine one day. I heard a new Softail Custom at the dealer last week that had just been put back together that sounded amazing. The guy who owns it is in Iraq right now. He bought the bike and had a lot of money put in it right away. Sent off everything and had the motor done up along with some other chrome goodies. Bike is putting out over 100 hp and torque. It sounded like a carb'd bike, which was what I really liked about it. I just don't see myself being able to talk my wife into lettin' me do that kinda work to my bike anytime soon.
