flush gas caps
[IMG]local://upfiles/49112/43FFB75A32FE4477B70312DB7EDF8EDA.jpg[/IMG]
[IMG]local://upfiles/49112/5AB04FA3ADF74CCC93947EF37CBC6A96.jpg[/IMG]
The price of the service manual is about $60.
For what it's worth, I got my service manual out for the '07 Heritage and looked up "fuel gauge." It's one page with a diagram (and not really a good diagram at that). The instructions for removing the fuel gauge aren't that complicated. Here's the main items I thought might be worthwhile:
1. Do not twist the left "fake" fuel cap (I'm assuming that's to keep you from twisting the wires inside). As noted, just pull up on the cap to remove it.
2. There are 3 wires that attach to the bottom of the gauge.
3. Take the seat off. Disconnect battery (book warns to do this to avoid "accidental startup" while working).
4. Remove fuel tank fasteners (there's a whole 'nother section on how to remove the fuel tank) and slide fuel tank back. You can probably figure out how to get the tank off. Fastners at front, on dash panel and at back.
5. The harness/gauge plug is fairly easy to disconnect. The wires run through a tube inside the tank.
6. There is a clamp at bottom of fuel tank holding the gage wiring in place, so look for it before you start poking or pulling on the wires too much.
7. There is a gasket that goes under the cap, and the book suggest you replace it when you remove the cap. If the new cap comes with a gasket then that's probably what it's for.
As noted, if you plan to do much to your bike -- even if you're just planning on basic maintenance -- then the manual is probably worth the $60.
