CHECKING THE OIL??
Old Jan 16, 2008 | 07:31 PM
MAX EVO's Avatar
MAX EVO
Default CHECKING THE OIL??
I can't find my manual so can someone tell me when checking the oil on an 06 Night Train.Should the bike be on the stand or up ? thx
Old Jan 16, 2008 | 07:36 PM
Luxe's Avatar
Luxe
Default RE: CHECKING THE OIL??
It should be on the side stand
Old Jan 16, 2008 | 07:37 PM
tmitchellof PG's Avatar
tmitchellof PG
It should be on the jiffy stand, with the engine warmed up, to get an accurate reading.
Tom
Old Jan 16, 2008 | 09:53 PM
tk353's Avatar
tk353
Why do they call it a jiffy stand?
Old Jan 16, 2008 | 10:24 PM
serge627's Avatar
serge627
ORIGINAL: tk353
As taken from wiki
Originally, most bikes had a frame mounted 'center stand'. On most older HD models, there was a center stand clipped to the inside of the rear fender requiring the operator to lift the whole back end of the bike to swing it into place under the frame, the "jiffy stand" was a quick easy method of standing the bike up without getting a hernia...the term jiffy stand was coined to distinguish the center stand from the side or "kick" stand as it could be deployed in a 'jiffy'.
Old Jan 16, 2008 | 10:33 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Look on the dip stick, doesn't it say check on the side stand?
Old Jan 17, 2008 | 12:13 AM
O6FXST's Avatar
O6FXST
Manual says to ride the bike enough to get fully warmed up. Parkit on the side stand and let idle for one or two minutes. Shut it off and check level on dipstick.
Old Jan 17, 2008 | 12:55 AM
bensonjv's Avatar
bensonjv
Ok, in my car, when it goes below the bottom edge of 'ok', the dipstick is graduated so that you add one quart. When you get below the 'ok' mark on a Softail, is there a standard amount of oil to add? Yes, I understand you add and then recheck. But knowing how much its low when the stick reads just at the add line would help to avoid overfilling.
Big_B_nIndy
Oil Archive (no new posts)
Oct 15, 2019 09:39 PM
MikeLaPlaya
Jan 19, 2015 02:26 PM
cactus road
Jul 1, 2010 09:20 AM
outlawrider
Sep 6, 2009 07:37 PM
am7010
May 27, 2007 09:10 PM
