103 Build and counter balance engine
Old Jan 29, 2008 | 03:40 PM
csbreeze's Avatar
csbreeze
Default 103 Build and counter balance engine
Bear with my ignorance but will the 103 build effect the counter balanced 88 engine? Will it vibrate more?
Thanks
Old Jan 29, 2008 | 08:54 PM
Nails's Avatar
Nails
Default RE: 103 Build and counter balance engine
Any increase in the stroke will result in a little more vibration...physics.
Old Jan 29, 2008 | 09:00 PM
csbreeze's Avatar
csbreeze
Thats what I needed to know. Thanks, I think I will stay stock with my Heritage. I bought the bike because of its smoothness. Great ride I love it.
Old Jan 29, 2008 | 09:43 PM
darkside's Avatar
darkside
Don't believe everything you read here. [:@]
Old Jan 31, 2008 | 05:35 AM
renoa18's Avatar
renoa18
The viberation is not really noticable. I had an 88 then upgraded to 95 and it ran smoother and I think viberated less then upgraded to 103. 103 viberate a little more at idle but that is it.
Old Jan 31, 2008 | 08:26 AM
rockerhead's Avatar
rockerhead
You would think that the engineering on these parts would take into consideration ,
the dynamocs of the couterbalancers. If it did not then it probably would not be offerred.
On a non counter balanced engine you can make H.P. by turning higher R.P.M. To make
H.P. on a rev restricted moter (due to bearing loads ac in the "B" motors) you have
to increase the displacement .Remember there is a place when "SIZE" matters.
Old Jan 31, 2008 | 01:54 PM
speedstick's Avatar
speedstick
I have a 07 heritage , big bore kit,260 cams,100 hp,100 lbs torque and almost no vibration
doug62
Jul 22, 2013 08:34 PM
Monty Blakley
Oct 30, 2011 07:26 AM
roadkinglobo
Jul 13, 2009 02:55 PM
08RoadKing
Jan 11, 2008 01:27 PM
dlstanf2
Exhaust System Topics
Feb 11, 2007 10:50 PM
