lowering an 04 fxst
Old Jan 17, 2006 | 08:07 PM
mhughes600's Avatar
mhughes600
Default lowering an 04 fxst
am considering lowering my bike 2" in the rear. wondering what effect it will have on the lean angle and overall handeling?
Old Jan 17, 2006 | 08:59 PM
JeffD's Avatar
JeffD
Default RE: lowering an 04 fxst
I lowered my '05 after a couple hundred miles, and never felt any difference in the handling. I never scraped anything in 5000 miles of riding.
Old Jan 17, 2006 | 10:45 PM
Peck's Avatar
Peck
I lowered my fxst 1 3/4" in the rear it handled a little different but most noticable is the rougher ride, it is ok for solo but my passenger complains a little, I still have stock shocks on it I would have to think that aftermarket shocks would make the ride smoother. I did scrape the exhaust a couple of times but then learned how far to lean before it scrapes.
Peck
Old Jan 18, 2006 | 10:00 AM
daboys53119's Avatar
daboys53119
Comfort is compromised two up but handling seemed much better on my Fatboy for what its worth.
Old Jan 18, 2006 | 09:30 PM
JLOCKHART29's Avatar
JLOCKHART29
Got mine lowered 1 1/2 inch using Progressive lowering kit on the stock shocks. Have had it for 20000 miles and love it. My wife rides on back all the time and doesn't complain. I have 3 ruptured disk and no problems. The only thing I have to watch is draging bottom of pipes on hard right curves.
Old Jan 20, 2006 | 03:51 PM
Boogie Knights's Avatar
Boogie Knights
Me too! Anybody got any advice for installing a Ness kit, the instructions are sparce, are there any top tips out there? I feel fairly confident in the spanner wielding department.[sm=signs003.gif] Thanks in advance dudes............[sm=icon_cheers.gif]
[IMG]local://upfiles/4765/AA58117332FF4305B0D90881398B1212.jpg[/IMG]
[IMG]local://upfiles/4765/4659B5CE957445C69666AAE61B2E539C.jpg[/IMG]
Old Jan 20, 2006 | 06:17 PM
JeffD's Avatar
JeffD
You will need a motorcycle jack, some hand tools, and a hydraulic press to take apart the shocks.
Compress the shock in the press, take out the snap ring, and then release the pressure from the spring. Take off the stock mounting bolt, and replace with the new pieces. reinstall the same way they came apart.
Old Jan 20, 2006 | 10:45 PM
JLOCKHART29
If you don't have a press you can use a floor jack and a trailer hitch or bumper of a truck. Put shock between jack and any solid object above it to compress shock but BE CAREFULL. The shock is under a tremendous amount of pressure!! I used the frount end loader on me tractor to compress mine!
Old Jan 21, 2006 | 01:52 AM
nightpork's Avatar
nightpork
lowered my 05 1 3/4 inch. Love the look and love the ride... but yes, 2 up is sacrficed!
Old Jan 21, 2006 | 05:44 AM
Boogie Knights
Cheers Jeff & JLOCKHART[sm=icon_cheers.gif], Mike probably would thank you as well, I will take the shocks to a local garage that has a press to dismantle, knowing my luck if I tried to do it any other way I'd ping the whole show into the roof![sm=bangbang.gif] I'll post once the deed is done.
