Kuryakyn Saddle Shields
Old Mar 15, 2008 | 09:03 AM
harley57's Avatar
harley57
Default Kuryakyn Saddle Shields
Just bought a 08 deluxe and put v&h true duals, big sucker air cleaner and a SERT. Having problems with heat on the left side. I think the exhaust is heating things up. At a stop light I'm afraid I might burn my legs....Has anyone installed and used the smoked Kuryakyn saddle shields? If so, did they work? Please post any pictures...thanks
Old Mar 15, 2008 | 11:56 AM
agapsdiver's Avatar
agapsdiver
Default RE: Kuryakyn Saddle Shields
If you mean these:
http://www.kuryakyn.com/products.asp?bn=Harley&ci=3613
yes, had them about 2 years and they work great. Painted
mine flat black.
You can see them in this pic.
[IMG]local://upfiles/6335/1045721778054E2D998531C459057282.jpg[/IMG]
Old Mar 16, 2008 | 12:44 AM
tk353's Avatar
tk353
If it gets that hot then there is something wrong. I had the heat until i did a stage one with the pclll. now after a run I can touch the heat shields and also the muffler and not get burned.
Old Mar 16, 2008 | 05:47 AM
coopmonte's Avatar
coopmonte
You might want to check your down load, sounds like it might be a bit lean
Old Mar 16, 2008 | 08:50 AM
Texas Fat Boy's Avatar
Texas Fat Boy
I have them and they do work.
There is much less heat on my thighs now.
Not sure what you need a picture, buthere goes:
Old Mar 16, 2008 | 03:40 PM
Hrd Rider's Avatar
Hrd Rider
I bought a pair for my 2005 Ultra Classic after stop and go traffic for 3miles up against Jersey Walls in the middle of August trying to get thru a roadconstruction site around Chicago while heading West. My right thigh was burnt so badly that it took 2 days of applying Cortisone Cream before I had any pleasure riding. My bike was Dynotuned perfectly and AFR was 14.2. It was just so dam hot, I even shut the engine off whenever I could.
That was back in 2006 and I had a difficult time finding the Kuryakyn SS backthen. Finally found a pair and they really did help. Then I think HD saw the need for them and they came out with a pair, I think in 2007. No pictures. Hrd Rider
Old Mar 16, 2008 | 05:26 PM
tk353's Avatar
tk353
My friend installed the thundermax and then removed the shields because he had no more heat.
Old Mar 16, 2008 | 05:46 PM
the general's Avatar
the general
i have the same problem with my deluxe . v&h true dules. i have short leggs and would burn the inside of my left thigh. i got the idea from some old school pics and got an oval heat shield and installed it over the main sheild with two stainless zip ties. looks great and works even better.part #30-0221 v-twin.
Old Mar 17, 2008 | 02:46 PM
harley57's Avatar
harley57
I was talking to a guy who owns a parts shop and he says there must be something wrong. One of my cylinders is hotter than the other and when you put your hands down by the duals, hot air only comes out of the right side muffler. I did the big sucker stage 1 and also had the SERT race tuner installed. I'm told it shouldn't be that hot. I think I will take it back to the dealer, maybe it needs a little adjustment. thanks
Old Mar 17, 2008 | 06:18 PM
J and K's Avatar
J and K
6th Gear
Hey General, Having the same problem with a Deluxe. Got any pictures of that part on your bike?
