Squealing brake question
Old Apr 6, 2008 | 04:19 PM
whylee's Avatar
whylee
Default Squealing brake question
I have had my X Bones for a couple of weeks now, have not been riding much due to the weather. I have 75 miles on the bike. The problem im having is that the rear brake (I use both front and rear) has a loud squeal when I apply the brake.
I dont know if it will stop or should I mention it to the dealer. None of my other Harleys ever did this.
Old Apr 6, 2008 | 04:24 PM
screamn_eagle's Avatar
screamn_eagle
Default RE: Squealing brake question
i would definitly call the dealer, first look to see if there is anything stuck between the pad and rotor, but i have 115 miles on my bones and there isnt any squeal at all
Old Apr 6, 2008 | 05:58 PM
whylee's Avatar
whylee
There is nothing stuck in the caliper that I can see, and there is no marks on the rotor. Just a loud squeal when the rear brake is applied.
Old Apr 6, 2008 | 06:12 PM
ajdrr's Avatar
ajdrr
Maybe an undersized pad - my honda had that same squeal on the front brake when used. They replaced the pads and all was fine. They said something about the pad tilting and shifting if undersized.
My 07 Deluxe rear disc had burrs on the through holes that created a scraping noise and a low hum (audible vibration) when used. I could feel the sharp edges with my fingers. I deburred with a dremel conical stone bit by hand and it's fine now.
Proper Brakes should never squeal. Do go to the dealer, it's their problem.
Old Apr 6, 2008 | 08:57 PM
Sarge4life's Avatar
Sarge4life
ORIGINAL: ajdrr
+1
Russty__
Apr 8, 2017 05:34 PM
kk6pg
Jul 10, 2012 05:32 PM
IMCochrane
May 23, 2011 07:28 PM
mark2004RK
Aug 10, 2006 03:17 PM
jbt
May 11, 2006 12:47 PM
