Rear Brake Squeel
Old May 20, 2011 | 02:33 PM
IMCochrane's Avatar
IMCochrane
Stage III
Default Rear Brake Squeel
I have a 04 Nightrain with a Precision Frameworx 300 rear tire kit on it, the back brake squeels, drives me F*cking mental, tried aignment, heard that a floating rotor would fix the problem, anyone else have some suggestions?
Old May 20, 2011 | 05:43 PM
poppavein's Avatar
poppavein
Try all the cheap anti-brake squeel solutions first (some kind of goo or pad on the back of the brake pad).
I had a squeel in my front wheel and floating rotors fixed it. (edit: but now I'm thinking it was more of a ringing sound than a squeal.)
Old May 20, 2011 | 08:44 PM
Other Sheep's Avatar
Other Sheep
Have you tried anything yet? If not go to your local Kragen pepboys o'reillys napa and buy a couple $1 packets of brake grease. Put it on the back side of the pads and go for a ride. Put a little on the two pins that hold the pads in place also. Gotta stop the vibrating harmonics.
Old May 20, 2011 | 09:19 PM
IMCochrane's Avatar
IMCochrane
Stage III
Rite on guys ill give that a go, appreciated!!
Old May 22, 2011 | 03:02 PM
F117ewo's Avatar
F117ewo
I think you meant brake pad adhesive, not grease. The adhesive works well on cars. My new ceramic rear pads squeal now and then too. I will try this on them, should do the trick.
Jake
Old May 23, 2011 | 07:16 PM
Other Sheep
Jake
No, I meant brake pad grease. It goes on the back of the pads where the calipers push on them. Not on the side that contacts the rotor. Go to one of the parts stores and you'll see little one dollar packets at the checkout stand.
Old May 23, 2011 | 07:28 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
What type pads are you running? If you are running stock harley pads, I bet one of your pistons is tight or tighter then its running mate. (pull caliper and wipe off exposed area of pistons. Push them back in (might need to drain a little fluid to do this) and slowly push brake pedel by hand and note if pistons come out the same. (Do not push piston out too far!) Its not alignment (caliper runs on axle) and tire should have noting to do with it.
YPD485
Aug 18, 2014 11:42 PM
mikelikesbikes
Nov 11, 2012 12:32 AM
OnTheFence
Wheels/Tires
Sep 23, 2012 01:23 PM
Navychief
Oct 1, 2007 09:05 PM
mark2004RK
Aug 10, 2006 03:17 PM
