Soft tail Brakes
Old Apr 12, 2008 | 12:03 AM
BWFXST05's Avatar
BWFXST05
Stage II
Default Soft tail Brakes
Recently Trailered my Bike from Ft. benning GA to Portland OR, went through major altitude changes and temps. when I off loaded my bike the rear brake pedal went all the way down. was working fine before, master cylinder is not leaking and there is plenty of fluid. any Ideas..I will start with bleeding acts like air, I pump them and they work once or twice. dont see how air got in though. can trailering cause this.?
Old Apr 12, 2008 | 05:45 AM
Vikingnomad's Avatar
Vikingnomad
Default RE: Soft tail Brakes
It sounds like you might have purged a seal somewhere in the brakesystem if you don't see any leaks anywhere...
Just my opinion
Bone
Old Apr 12, 2008 | 08:27 AM
FXSTI Guy's Avatar
FXSTI Guy
Strange...don't really see how simply trailering your bikewould cause a brake failure...and as far as elevation changes go I routinely ride from 5,000ft. (starting point) to 8,000 ft.+ elevations and have had no brake issues...I'd flush out the old brake fluid completely and refill w/ FRESH (as in brand new) DOT #4...bleed it good and go from there.
Old Apr 12, 2008 | 11:47 AM
renoa18's Avatar
renoa18
Yeah I would dump the old fluid and then start all over.
Old Apr 12, 2008 | 01:15 PM
Stretchman's Avatar
Stretchman
Did you park it on the trailer somewhere out of sight? Check the bleeder valve.
Old Apr 12, 2008 | 11:14 PM
BWFXST05's Avatar
BWFXST05
Stage II
Oh well tried everything. went ahead and ordered a master cylinder kit its the last thing it could be. So strange no leaks , no air , nothing. Holds pressure sitting there then I roll it out to the street and then no pressure. Brakes were working fine as i put it on the trailer. oh well. thanks for the suggestions.
Lotaluck
Oct 19, 2016 03:10 PM
wuaname
General Topics/Tech Tips
Jul 22, 2014 08:00 AM
mikebehr00
Wheels/Tires
Feb 23, 2014 11:16 AM
MY883
Jul 8, 2012 10:06 AM
WARG
Jul 13, 2008 04:04 PM
