95or103
Old Apr 27, 2008 | 10:55 AM
harley1969's Avatar
harley1969
Default 95or103
I have a twin cam 88 stock motor in my 03 softail standard. Thinking about boring it out to 95 or 103inch. Which one would you guys prefer to put it in your bike? And a rough estimate on how much ill be spending upgrading to a 95 or 103? Id appreciate your advice!
Old Apr 27, 2008 | 11:19 AM
fxstbharley2008's Avatar
fxstbharley2008
Default RE: 95or103
Dont know how much you will spend - but when I had my 2000 88ci
I upgraded it to 95ci using Screaming Eagle parts with cams and headsand just about got 100 hp out of it.
It ran great!
Old Apr 27, 2008 | 11:22 AM
WARG's Avatar
WARG
Default RE: 95or103
I am thinking of doing the 95" kit, don't want to put the cash out for the 103". I lot of guys here have gotten great resutls with just the 95. A lot have used aftermarket cams like from Andrews, Head Quarters, or the SE 204 cam.
Old Apr 27, 2008 | 04:09 PM
DocTkd's Avatar
DocTkd
Default RE: 95or103
My understanding is for the 88 engine going to 95 only involves boring the cylinders. Going to 103 involves stroking the engine - much more expensive.
Old Apr 27, 2008 | 07:19 PM
wiseguy2day's Avatar
wiseguy2day
Default RE: 95or103
Doc is right about that. I've been having the same dilemma about 95 or 103. . I'm glad you started this thread.
Old Apr 27, 2008 | 11:51 PM
spike95's Avatar
spike95
Default RE: 95or103
Stroking to 103 costs a whole lot more than just the 95" big bore. You actually have to modify the cases to stroke it. You can get kits from Head Quarters, GMR, Zippers, or a host of other performance companies that will easily produce well over 100hp/100tq out of a 95". Going from a stock 88" to that willbe a huge difference in power output.
Old May 3, 2008 | 11:49 AM
esyrdgcwby's Avatar
esyrdgcwby
Default RE: 95or103
Well it mostly depends on how much money you want or can spend on it & then what kind of horse power you are looking for? Usually a properly set up 95" kit will get you a 100 hp & torque, & generallydepending on what your dealers labor rate is & what componets you already have installed this modification should cost between 4K & 5K dollars, this should include a good set of cams, andrews 50g cams or SE 211 cams , SE heads ,or ported & polished , SE flat top pistons, SE a/c set (use the K&N filter) you can actuall buy the SE backing plate (chrome) , o-rings & bolts seperatly , then the K&n filter for less than the HD ac kit. & a goo set of pipes , vance & hines pro pipe ,cycle shack dual staggered, V&H big shots, & rinehart2 n 1 are all good choices, ifyou have fuel injected boke a SE race tuner is a must, have a qualified tech create you a customer map, if you do all this i can guarentee you will get 100 + hp & torque from you bike.
The only reason to do a 103 is if you want more hp and you got money to burn , or if in my case you engine blows up !
Old May 3, 2008 | 11:58 AM
Lamo70's Avatar
Lamo70
Default RE: 95or103
MY best friend went from 88 to 95 on his '02 Deuce, everything was ok until he went and had a Stage 3 done, he says the Stage 3 ruined the performance in his bike. Just wanted to mention that.
Old May 3, 2008 | 11:38 PM
95CHUCK's Avatar
95CHUCK
Default RE: 95or103
I agree with going with the 95 inch. I just wished I would have done my 95 inch conversion sooner. I waited 2 yrs after buying my bike.
Old May 5, 2008 | 12:18 AM
renoa18's Avatar
renoa18
Default RE: 95or103
I would go with the 95 you can get great performance out of a 95. Unless you are drag racing I would go with the 95 good set of cams, pistons and heads. Also if you do that you need a SERT.
emerican19
Feb 10, 2014 10:58 AM
AZRenegade
Exhaust System Topics
Mar 17, 2012 09:53 PM
tpburly
14
Mar 25, 2010 09:40 AM
marinepilot81
16
Nov 14, 2008 09:53 AM
fiddledicksr
Nov 7, 2006 12:38 PM
