PC Dyna maps on Softail?
Old Apr 28, 2008 | 05:58 PM
clenaghen's Avatar
clenaghen
Default PC Dyna maps on Softail?
I understand that the Power Commander Dyna maps can be used on Softail bikes and have found a match for my 02 Fatboy, except the Dyna map is for an '07 with O2 sensor eliminators. Would there be a problem using this map on my '02 Softail?
Old Apr 28, 2008 | 06:53 PM
hspring03's Avatar
hspring03
Default RE: PC Dyna maps on Softail?
The 02 is an 88..The 07 is a 96.....I don't think you have a match
Old Apr 28, 2008 | 08:24 PM
clenaghen's Avatar
clenaghen
yeah, duh... Thanks for the stupidity check!
Old Apr 29, 2008 | 04:25 AM
raaaaaa's Avatar
raaaaaa
why do you need to use a dyna map when there are an endless supply of maps for the softail
Old Apr 29, 2008 | 05:01 AM
Vikingnomad's Avatar
Vikingnomad
Did you check for your setup here??
http://www.powercommander.com/powerc...32&yr=2002
Bone
Old Apr 29, 2008 | 06:54 PM
clenaghen's Avatar
clenaghen
I stumbled across the dyna map as a perfect match to my setup. I am not looking for a Dyna map in particular; just found one that matched perfectly, besides the obvious difference in engine size.
Old Apr 29, 2008 | 06:56 PM
clenaghen's Avatar
clenaghen
Yes, I have gone through the map downloads on the Powercommander website. There are not a lot of (well, there is 1) maps for the Samson BG3 exhaust.
Delldoe3030
Aug 14, 2015 09:17 PM
ghettoblasters
Mar 12, 2013 06:07 AM
Tilter
Nov 18, 2009 09:55 AM
jlb0038
Aug 9, 2008 03:10 PM
05rkcustom
Aug 3, 2007 07:54 PM
