Simple fix?
Old May 2, 2008 | 07:27 PM
fonemann's Avatar
fonemann
Default Simple fix?
Rear brake on 07 FB sticking after brake applied, is there an easy way to fix, went to dealer he said "somtimes they do that" bike has 800 mi ?? sounds very loud and irritating...thanks
rick
Old May 2, 2008 | 07:35 PM
wiseguy2day's Avatar
wiseguy2day
Default RE: Simple fix?
I don't buy that 'it happens'. That sounds like BS. I'd go to another dealer (or call around). That's waaaaayyyyyy too dangerous to 'let it work itself out'
Old May 2, 2008 | 07:36 PM
deadeye's Avatar
deadeye
My brake did the same thing starting around 700 mi. The dealer mechanic took the brake apart at 1000mi service and cleaned it out with brake cleaner. This fixed the problem.
Tolerance is very close between pads and disk on new bikes so if any brake dust or dirt gets behind the pads, they will drag on the disk.
Old May 3, 2008 | 01:49 AM
tk353's Avatar
tk353
My back one did the same and brake cleaner fixed it until another 700 miles and more dust. i just changed to
also the back caliper is not the same as the front. It uses the same as the springer.[align=center]http://www.lyndallracingbrakes.com[/align][align=center]Z-PLUS
PAD
[/align][align=center][/align]
Old May 4, 2008 | 03:21 PM
bdejong11129's Avatar
bdejong11129
I wouldnt take the "sometimes happens" crap on a new bike with only 800 miles on it. Remember how much you paid for it and have them take care of it.
Old May 4, 2008 | 03:29 PM
xxxflhrci's Avatar
xxxflhrci
Is it sticking/ dragging or are the pads simply making noise? The pads always make contact with the disk and usually will be noisy until you ditch the crappy metallic OEM pads and put on some Kevlars.
Old May 4, 2008 | 03:51 PM
Fightn_Tiger's Avatar
Fightn_Tiger
tell the mechanic at the dealership some customers are "sometimes dicks"..and tell them to fix it or your taking your business elsewhere....dealers need to understand that the paying customer has the advantage
DeathProof72
Jun 21, 2010 08:46 PM
sixgun1
Feb 7, 2008 10:22 AM
07 Fatty
Sep 11, 2007 09:06 PM
Earlman
Apr 3, 2007 11:49 PM
FatRick
Mar 20, 2007 12:13 AM
