Front brake effectiveness?
Old Apr 3, 2007 | 01:25 AM
Earlman's Avatar
Earlman
6th Gear
Default Front brake effectiveness?
I have just over 200 miles on my 07 FLHTC and the first thing I noticed from previous bikes is the front brakes are very soft. Has anyone else noticed this on Harleys compared to metric bikes or should I take it to the dealer for a check up?
I remember front brakes being the most effective brake and find these the opposite, maybe I just need to get the feel of them....
Old Apr 3, 2007 | 01:32 AM
fatboylust's Avatar
fatboylust
Default RE: Front brake effectiveness?
Have it checked to confirm it is working properly. The lever effort may be higher than you are used too due to the additional weight of the HD over the metrics. Consider the front brakes on your FLHTC aren't any larger than those on similar metrics but the HD weighs 100lbs or more usually.
FBL
Old Apr 3, 2007 | 01:55 AM
grinner's Avatar
grinner
I have the same bike w/100 more miles than you. I almost posted the same issue. During my first few rides I was shocked at how much more effective the rear brake was than the front. I think mine fixed itself or I got used to it, as I can now stop very quickly. Maybe ride 100 more miles and see how it feels?
Old Apr 3, 2007 | 01:58 AM
unclekunkle's Avatar
unclekunkle
ORIGINAL: Earlman
Earlman, my last bike was an FJR 1300...had a lotta front brake. Turns out the RG's gotta lotta front brake too, just feels different. Much of this different feel is the softer front suspension, (big dive on heavy application). Harley's also have bigger master cylinder's and calipers requiring more hand pressure to achieve the same effect as what you're probably used to.
You got over 200 miles now, so they're broken in... nows the time to go "get used to them".
Find a road thats condusive to panic stops and work up to giving yer front brake lever the big squeeze. I think you'll find that the dual rotor brake setup on the touring models are quite effective. I take exception with your comment above (in orange)... Don't ever think the rear brake on any motorcycle is the more effective one. On the backroad, the test is: How quickly can I stop with out locking em up!
Old Apr 3, 2007 | 02:10 AM
btefft's Avatar
btefft
My 06 RK Classic has a great front brake. Real stopping power.
Just wondering, could one of you brake calipers be "lazy" or not being applied with the same force as the other?
Hack
Old Apr 3, 2007 | 02:45 AM
PapaTravis's Avatar
PapaTravis
I have owned a few metrics and I have always used the front break more. Maybe because when I need to stop quickly, my hands squeeze the clutch and brake faster than I can move my foot to the rear brake lever (I am tall and use my highway pegs all the time). On my rk custom, when I first got it, the front break noise stopped me from using it much, so I relied mainly on the rear. After fixing the noise, I find myself using them fairly equally. In fact, the two times on my harley I needed to stop NOW, I have locked up the rear and slide sideways both times.
So far, I have handled that without a problem or a wreck, but I wonder in the future if that will be the case. I ride very fast, but am always looking far ahead and trying to anticipate everyone elses actions. I always do the same in the truck. My wife is always amazed how many times I have avoiding accidents, and the police, by being observate of my surroundings. I now drive the speed limit everywhere in the cages I own. But just can't seem to let off the throttle on the bike.
In any event, these bikes are heavy. All I can say is to do like unclekunkleand practice a little more. People say 'practice makes perfect', I say- ONLY PERFECT practice makes perfect!
Old Apr 3, 2007 | 02:48 AM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
The lever is soft because of the expansion of the stock rubber brake lines when the brake is applied. Easy fix, a set of steel braided brake lines and thoroughly bleed the system of all air bubbles. Better pads such as the Lyndall Racing Z pads make a big difference in stopping power and brake lever feel, also.
Old Apr 3, 2007 | 08:11 AM
TUCK's Avatar
TUCK
I installed Lyndell pads, s/s braided lines, and floating rotors. Made a huge difference.
Old Apr 3, 2007 | 09:26 AM
SG 1's Avatar
SG 1
I have not noticed any problem with the front brake. It seems to be very effective to me. The back brake will lock up and has taken some getting used to for me. On my last bike (VTX 1800) I could stand on the pedal hard and not lock the back wheel. The back was linked to the front sending patial stopping power to the front wheel. I use both brakes every time I stop. Definately gotta be carefull not to lock the rear on the SG. I've made one semi emergency stop and the back did'nt totally lock up but it was barking.
Old Apr 3, 2007 | 09:42 AM
btefft's Avatar
btefft
SG 1, how did you link the two brakes together? I wouldn't mind being able to apply both brakes with just my handlebar lever.
Hack
