Front brake effectiveness?
Old Apr 3, 2007 | 11:47 PM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
Default RE: Front brake effectiveness?
ORIGINAL: 89FLHT
Eyesspy - did you build the SS lines a piece at a time, or were you able to get a complete setup from a Russel, etc. ?
I put on a kit from Russell. Had the lines with pre-fit banjos at the right angles, and a chrome distribution block.
[IMG]local://upfiles/12830/C08AA6BEC89C4407B23365C239C2C109.jpg[/IMG]
[IMG]local://upfiles/12830/C7C6117D71004A5E9F43D6E5F2EF1F5C.jpg[/IMG]
[IMG]local://upfiles/12830/2CEEC01D78784451BAE2FF18EB6342BF.jpg[/IMG]
[IMG]local://upfiles/12830/5B0599985F264C67A47963A7A17D69EF.jpg[/IMG]
Old Apr 3, 2007 | 11:49 PM
Eyespy's Avatar
Eyespy
ORIGINAL: gman
the feel at the front brake lever on my single rotor '06 WG is really solid. I noticed however on my '07 UC that it also felt abit soft. Thought maybe it was just my bike, and maybe it wasn't bled properly and some air was in the the lines. bled the brakes, using a putty knife to move the pads back a bit, but this didn't help. went to the dealer and tried the brakes on all the new UC sitting in the showroom. they all felt the same, just like mine. then went to a SE UC, and it was solid, like my WG. Difference was that the SE had braided lines, so my next step is to put them on mine. have heard about rubber lines expanding a bit. don't see mine moving around at all when you squeeze the lever, but am going to swap for braided lines in an attempt to fix this.
[IMG]local://upfiles/12616/243B6E9CDDB64D988569391887306B98.jpg[/IMG]
gman. just hold one of the stock rubber front brake lines bwtween thumg and forefinger, and squeeze the brake lever. You will feel the expansion, even though you don't see the line moving.
don bowman
Nov 26, 2012 08:13 PM
Pelonz
Sep 18, 2012 11:19 PM
cohokiller
Shovelhead
May 25, 2008 09:59 AM
Figstr
May 4, 2008 10:26 AM
FLHTS
Dec 28, 2006 11:51 PM
