wrong cleaner on winshield
Old May 3, 2008 | 01:20 PM
gun smoke's Avatar
gun smoke
Default wrong cleaner on winshield
I messed up my new 2006 HD deluxe winshield by using the wrong cleaner on her,I tried the scratch remover harlely sells but no luck,it has swirls in it.I want to buy a replacement winshield and found a couple places like cee baileys and rifle.
Neither had stock you have to add inches here & there.
I want the exact one that I bought from harley davidson,I looked under hd parts but only seen the complete set with hardware.
Overall height 26.3"; height/width 23.1" is what I need.
If anyone knows where I can find one I would appreciate it.
THANKS
MATT D.
Old May 3, 2008 | 03:22 PM
mikef's Avatar
mikef
Default RE: wrong cleaner on winshield
Take it to the local plastic shop and have them cut you a new one. Make sure they us GE Lexan MR10. That is polycarbonate with a hardcoating. Make sure they use the correct thickness. I bleieve it is 1/8" or .125 thick.
They will unbolt it from the frame make a new piece an install it. It will save you money.
Old May 3, 2008 | 05:01 PM
DCS's Avatar
DCS
If you do not have the 08 HD parts catolog go to a dealer and look up page # 256.
There is replacement windshields only. Tall, Standard-Height, and Low-Profile all in either clear or smoked. $134-150
Later,
Dan
Old May 3, 2008 | 08:10 PM
1badtc88's Avatar
1badtc88
mikef real nice fatboy all it needs now is a badlander seat.
Old May 3, 2008 | 08:58 PM
TexFordD's Avatar
TexFordD
Go get some Mequiers PlastX. It's the stuff they use for foggy head lights.
You can either elbow grease your self to death or apply with a buffer at a VERY SLOW speed.
Take your time. Post back and let us know how it turned out.
I went on a toy run last X-Mas and they stuck a sticker on the shield. Well between the sun and the glue it screwed it up bad. Then I tried to get it off and that did it.
I tried the Mequiers as a last resort and was absolutly amazed.
Have recommended it since and nothing but rave reviews
Old May 4, 2008 | 11:13 PM
Harley03joe's Avatar
Harley03joe
GunSmoke
Go Here And Get You A New Winshield
www.memphisshades.com
You Will Be Very Happy
Look At Mine
Old May 5, 2008 | 08:02 PM
BigMike17's Avatar
BigMike17
ORIGINAL: TexFordD
+1
Old May 5, 2008 | 10:37 PM
kentuckydave's Avatar
kentuckydave
I used RainX on a couple of windshields and screwed them both up. I tried the Harley cleaner/polisher to no avail. Now all I had was swirls.
My son has a car buffer so we bought a new pad and got some polisher for clear coat paint. That did the trick. It took out the swirls and not to say its perfect because it isn't but we did get about 95% of the swirl and original damage out of the windshield.
I don't know if but what a glass replacement place such as Harmon glass might have a buffing method that is superior to what we did but it can't hurt to make a few calls. I'd try it before I coughed up 350-400 for a new shield.
Good Luck.
Old May 5, 2008 | 11:04 PM
Harley03joe
ORIGINAL: kentuckydave
Good Luck.
I'd try it before I coughed up 350-400 for a new shield. ???? WHAT
Why So Much Money
When You Can Get A Replacement
Memphis Shades Replacement Plastic
For $85.45 Like I Did And Different Heights I got 19 inches Black Bottom
Memphis Shades - Products Home
Old May 9, 2008 | 09:48 PM
mikef's Avatar
mikef
ORIGINAL: DCS
Later,
Dan
Anyone have a part number for the smoked low profile replacement plastic for the windshield?
Greg Di
May 31, 2013 12:15 PM
fmnspooch
Oct 5, 2011 01:57 PM
aquaelvis
Apr 30, 2011 01:41 PM
rideline
General Topics/Tech Tips
Jul 4, 2009 09:19 AM
08custom
Feb 6, 2009 06:24 AM
