I asked this question in the Exhaust Tech section too but figured I might get more responses here.
Does anyone have map for the Power Commander for a 2007 Softail running a Screamin' Eagle air filter, Hooker Troublemaker pipes, stock ECM, and O2 sensor eliminators installed?
If not will the map from Power Commander for V&H Big Radius pipes with Screamin' Eagle air fileter, stock ECM, and O2 sensor elimiators installed be close enough?
That is the map that I used, I have the sameHooker Troublemaker pipes and the Pro R hypercharger, I downloaded the map for big rad. and screaming eagle air filter and my FXSTC runs like a scalded ape, I have not had it on a dyno however it really runs great!! good luck with yours!!
Great news and thanks for the info. My brother just got his Troublemakers on last night and the local indy couldn't dyno before we leave for MB tomorrow AM. Can't fault the indy, a little planning on my bro's part would help here. I was hoping that map would get him by so we can head off to MB. Thanks again!
