Quick Clutch Question
Old May 15, 2008 | 12:39 PM
fonemann's Avatar
fonemann
Default Quick Clutch Question
When I put my 07 FB In gear with clutch pulled (obivously) the
bike lurches FWD, which way do I turn the adjusting nut, do I?
1.turn the nut to make the threaded part longer?
2 turn the nut to make the threaded part shorter
3. adjust while running with help till it stops pulling?
thanks
Old May 15, 2008 | 01:19 PM
DCS's Avatar
DCS
Default RE: Quick Clutch Question
Are you asking about the adjustment on the slack adjuster for the clutch lever on the handle bars or the clutch adjustment screw that is held in place by the lock nut inside the primary? I would do a full clutch adjustment if it were me. Loosen the slack adjuster for the hand lever until it is very loose then you have to take off the inspection cover for the primary to adjust the clutch. Lock nut loosened up then take allen wrench for adjusting screw and turn in until lightly seated & then back out 1/2 to 1 turn, lock the nut back down put everything back together and adjust clutch lever's free play. You will be able to tell wich way to turn the clutch lever's free play adjuster by how much or how less of free play you are getting in the clutch lever depending on which way you are turning the adjuster. You can do a search for CLUTCH ADJUSTMENT here & find more informative directions.
Later,
Dan
Old May 16, 2008 | 01:10 PM
fonemann's Avatar
fonemann
THANKS DAN!
ElectraJim
Nov 24, 2016 09:45 AM
BamBam60
EVO
17
Aug 7, 2014 05:04 PM
ebeattie
Jun 4, 2013 01:55 PM
68_sporty_89
Ironhead
Mar 23, 2012 07:41 PM
pavin
Apr 15, 2011 08:40 PM
