Belt Rubbing Tire
Old May 18, 2008 | 05:51 PM
jeffwest5599's Avatar
jeffwest5599
Default Belt Rubbing Tire
I am running a 1996 Bad Boy. I had a new rear tire put on about a month ago. Pulled off a 140/90/16 and installed the same size tire. No problems. YesterdayI started noticing a sound when backing up my bike. Looked at the rear tire and it appears the belt is now rubbing the rear tire. You can see the wear mark on the tire. Any suggestions on what this could be or how to fix? Any help would be appreciated as I have to hit the road on Friday to a motorcycle rally and really need to get this fixed prior to that.
Old May 18, 2008 | 07:36 PM
DeuceRyder's Avatar
DeuceRyder
Default RE: Belt Rubbing Tire
well im not sure if it will help you but I just ordered a pully spacer for mine. You can order them pretty thin, less than .250 if need be
Old May 18, 2008 | 07:41 PM
darkside's Avatar
darkside
Sound to me like the rear tire needs to be aligned properly.If it's cockeyed it will cause the belt to track off on the pulley.Did you install the spacers correctly when you put it back together?
Old May 19, 2008 | 10:21 AM
hdrdrd17's Avatar
hdrdrd17
alignment or spacers. if you got a svc manual they tell ya how to check the rear alignment. its actually quite simple.
Old May 20, 2008 | 11:52 AM
mjmangus's Avatar
mjmangus
+1 check the alignment
ORIGINAL: hdrdrd17
Old May 20, 2008 | 12:11 PM
Harley_Dude's Avatar
Harley_Dude
Whoever put it back on didn't get it in straight.
Old May 20, 2008 | 04:08 PM
Mikey 1450's Avatar
Mikey 1450
You have probably already done this, but check you tire pressure.
medevac121
Mar 19, 2018 07:34 PM
gtrplyr
Nov 10, 2011 10:29 AM
jm1211
Feb 7, 2010 02:16 PM
HutchNJ
May 27, 2008 02:22 PM
jeffwest5599
May 18, 2008 07:24 PM
