Rocker Mods.
Old May 21, 2008 | 02:32 PM
doc1's Avatar
doc1
Default Rocker Mods.
I just purchased my Rocker and I've had big problem with the license plate mount blocking the view of that beatiful rear fender. I removed the original bracket and moved it to a sidemount (easy and free mod). Now the only dilema I am having is what to do with whats left over. Any ideas??
Old May 21, 2008 | 02:33 PM
doc1's Avatar
doc1
Default RE: Rocker Mods.
Not sure if that picture is working.
Old May 21, 2008 | 02:41 PM
doc1's Avatar
doc1
One more try
[IMG]local://upfiles/62138/27964346048A42B48B78284B6F19667A.jpg[/IMG]
Old May 21, 2008 | 03:37 PM
ChosenDFW's Avatar
ChosenDFW
How did you do the modification of the license plate to a sidemount?
Old May 21, 2008 | 04:34 PM
cnd_rocker's Avatar
cnd_rocker
6th Gear
nice job on the plate
I spoke to the salesman today and i ask him the same question. He to me there might be some revit to cover eack hole "so he told me" aswell there is one guy on this forum that put some .50 bullet shells, it looked cool. Good luck and don't forget to show us the final product.
Old May 21, 2008 | 04:46 PM
doc1's Avatar
doc1
Take note on the stock mounting bracket where the reflector mounts to the brackety. Take off the reflectorshorten that piece of the bracket by 1" and drill a new hole. Then put the bracket in a bench vice and bend that leg of the bracket 90 degrees. Now you can paint the bracket and it will mount directly to the exsisting belt guard bolt. Very quick and easy. I know it's not as custom as other brackets out there, but when your savings account was just drained on a deposit (like mine) it works for a budget fix. Hope that helps.
Old May 21, 2008 | 05:02 PM
RockerMike's Avatar
RockerMike
That looks great. What about a light for the plate, I believe it is required. I'm having my fender done now, I will post pics and let you know what I did when its complete.
Old May 21, 2008 | 06:53 PM
wkenddad's Avatar
wkenddad
Personally I was hoping someone would come out with a low profile LED tail light that has about the same shape and mounting holes.
I would then turn the turn/tail lights into turn signal only.
Let the tail light be the tail light.
Then side mount the plate with a nice LED.
Also I don't think this plate mod is legal in any of the 50 states
Old May 21, 2008 | 08:15 PM
MJD's Avatar
MJD
For 500 dollars the dealer took my tag and relocated it to the side. They also removed the entire housing, filled the holes and painted it. It looks great. Picking it up tomm and will try an post pics.
Old May 21, 2008 | 08:44 PM
doc1's Avatar
doc1
Hi. Thanks for the compliment. Yeah that under the seat license mod was an idea I was playing with until I converted my bracket. By the way, how do you get the pictures to show up in the thread like that??
