rpm s on fat boy
Old May 27, 2008 | 08:36 PM
ardbark's Avatar
ardbark
Default rpm s on fat boy
have a 08 fat boy and at it idles at 950 - 1000 rps does this seem high
if so how do i lower it?
Old May 27, 2008 | 09:59 PM
08fattoy's Avatar
08fattoy
Default RE: rpm s on fat boy
I've read here by others that 950 to 1050 is accurate. I have a PCIII and my RPM's are in that range. It doesn't idle at say 950, it varies between 950 and 1050. The EFI models idle higher. Hope that helps.
Old May 27, 2008 | 10:05 PM
Pres1's Avatar
Pres1
Idle is not adjustable on EFI bikes as far as I know.
Old May 27, 2008 | 10:31 PM
my02fatboy's Avatar
my02fatboy
I just installed a tach on my 02 and according to the service manual idle should be between 1000 and 1050 on the efi model. I also have the pcIII and stage 1 download and had the bike through the 20k service a few weeks ago. Probably doesn't pertain to the 07/08 model but figured any info is helpful.
Old May 27, 2008 | 10:51 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
You can adjust the idle on EFI bikes, but you need to use a SERT on the stock ECM or replace it with one that you can reprogram like the Thundermax.
I have a TMax in my bike and dropped it down to about 900so it has that nice lumpy idle the oldercarbed EVO's and Shovelhead's had.
Old May 27, 2008 | 10:54 PM
08fattoy's Avatar
08fattoy
Pres1, love the paint job. Side question. Wanting to add AUX. lighting up front. Obviously, between the HD deluxe with turn signals and the Fatboy version without signals. Are you happy with your setup or would you recommend the more expensive deluxe version? I kind of like the signals on the handlebars. I can see they're reflection in the headlight and it's easy to see when they're on. Do you have any pics from the front of your bike?
Old May 28, 2008 | 06:44 AM
Pres1's Avatar
Pres1
That's funny you say that. I just got done moving my signals down below the aux lighting. At first, I liked the signals up, but now I just think it cleans up the bars. Good luck with your new toy.
bskinheli
May 16, 2018 12:52 PM
Double Trouble
Harley Davidson Videos
Aug 15, 2012 06:59 PM
tmac00333
Oct 26, 2011 03:40 PM
KYFATBOB
Feb 23, 2010 09:57 PM
smikesmailbox
Oct 20, 2006 12:27 AM
