I have a 2006 heritage classic efi with se air cleaner vance and hines pro pipe and pciii, when i crack the throttle it seems to come down slow compared to carb models. Is this normal.
Throttle adjustment
At the hand grip
Front cable A is throttle
Back cable closes to rider cable B
Back off both throttle adjustment nuts found under rubber sleeves
Center the front wheel with the bike look at the throttle body from front of bike
Rotate handle bar throttle full open
Tighten cable A until Cam device touches stop tighten lock nut
Release throttle
Turn front handle bars to right
Do not touch throttle
The cable next to air filter is Idle cable B the cable casing goes into a spring sleeve guide use a trouble light look carefully
Tighten cable B until cable housing just touches the spring tighten lock nut
return steering to center
Start bike and ride!
Also lubricate items while you are near them
Stephen95
Reference : 2005 softail manual page 1-48
manuals are about $80 well worth it.
You could have it dyno tuned... espically with intake/exaust mods. A PowerCommander is a great investment, and you would have the option to have a simple map downloaded or a custom map made for you bike. or maybe a professional could just direct link to it and set each throttle position.
