HD run/brake/turn module problem
Old Jun 14, 2008 | 09:26 PM
khnt's Avatar
khnt
Stage II
Default HD run/brake/turn module problem
I installed an HD run/brake/turn module for my rear turn signals, but it doesn't seem to work right.
It lights up bright on both sides as if the brakes are applied when in the run mode.
When I apply the brakes the left rear turn signal dims and flashes real fast, and stays that way. I changed the bulb too, but it still does it.
When it does that, I turn on the turn signal and it flashes normally, when I turn the signal off, it goes back to dimmed and flashing fast.
I do have an LED tail light, don't know if that makes a difference.
Thanks for any help or suggestions.
Old Jun 14, 2008 | 09:31 PM
Airborne350G's Avatar
Airborne350G
Default RE: HD run/brake/turn module problem
Might need a load equalizer on the brake light. Change the light our for a standard and see how they work then.
Old Jun 14, 2008 | 09:59 PM
Asylumcycle's Avatar
Asylumcycle
Had problems with mine too. buddy that works at HD shop told me they have lots of problems with them. took it out and got an amkt one and have never had a problem.
Old Jun 14, 2008 | 10:03 PM
bdejong11129's Avatar
bdejong11129
Using it on my bike, installed it a few weeks back and it has been working good for me but I have a standard tail light.&nbsp\\; It after trying a regular bul it is still not working the just bring it back.&nbsp\\; Should be under waranty.&nbsp\\; Sometimes you get a bad part..
Old Jun 14, 2008 | 10:06 PM
raaaaaa's Avatar
raaaaaa
the harley ones are garbage you have to get the kuryakyn ones they work great. I have them on 3 of my bikes, sportster and 2 softails&nbsp\\;
Old Jun 15, 2008 | 09:13 AM
jimmers1817's Avatar
jimmers1817
Mine has worked fine for several months.&nbsp\\; Try airborne's suggestion.&nbsp\\; If that doesn't work, obviously you have a defective unit.
Old Jun 15, 2008 | 10:32 AM
Moondognyc's Avatar
Moondognyc
I believe that "Badlands" makes the best unit.
&nbsp\\;
&nbsp\\;
ORIGINAL: khnt
Old Jun 15, 2008 | 10:52 AM
05 HD Deluxe's Avatar
05 HD Deluxe
Beeen running the HD one with no problems for six months
Old Jun 15, 2008 | 04:48 PM
hogrider1960's Avatar
hogrider1960
Stage I
The problem is caused by the LED's. The run stop is made for reg bulbs. If you stay with LED's get a load equalizer all will be fine.
ClayM
Jan 10, 2015 01:38 PM
ClayM
Electrical/Lighting/Alarm
Jan 6, 2015 01:30 AM
jsims002
May 15, 2013 05:11 PM
BigDaddyMike
May 5, 2010 10:12 PM
Fisherman 77
Feb 18, 2008 09:46 AM
