Oil Change - Filter spill when removed
Old Jun 22, 2008 | 08:41 AM
tmitchellof PG's Avatar
tmitchellof PG
Default RE: Oil Change - Filter spill when removed
I also use aluminum foil under the filter. Some owner's drill a hole in the filter to allow the oil to drain out, but make sure you break the filter loose first. I&nbsp\\;spray brake cleaner on the engine where any oil gets on. It cleans up without leaving any residue.
Tom
Old Jun 22, 2008 | 09:19 AM
tk353's Avatar
tk353
working as designed. just another excuse to go to the car wash.
Old Jun 22, 2008 | 09:25 AM
grumpy irish again's Avatar
grumpy irish again
tried all the obove and said the heck with it now just take the thing off then take brake cleaner and wash off the spill simple and cleans the front of the engine real well
Old Jun 22, 2008 | 09:35 AM
clutchglass's Avatar
clutchglass
Check out the Billetcool oil cooler. it'll make changes easier (no more crank position sensor in the way)...and filter removal/clean up is a snap. http://www.billetcool.com/&nbsp\\;\\\\\\;
-clutch-
P.S. Does a a great job of cooling too.
&nbsp\\;\\\\\\;
[IMG]local://upfiles/10668/0060762A2E134D2EB4AA0FE7CBF005BE.jpg[/IMG]
Old Jun 22, 2008 | 09:46 AM
Jerseytwin's Avatar
Jerseytwin
+1
Old Jun 22, 2008 | 10:23 AM
forever 2 wheels's Avatar
forever 2 wheels
I use a plastic grocery bag around the filter after I loosen it up. The filter falls into the bag and that's all she wrote. No mess, give it a try!
[IMG]local://upfiles/46904/1834FB0353B24C5CA1C78C9CC3059770.jpg[/IMG]
Old Jun 22, 2008 | 10:36 AM
erockguide's Avatar
erockguide
I got some stuff called Grease Lightening. After spraying the area around the filter and voltage regulator, the engine there is blacker (cleaner) than the rest of the engine. Wow!
&nbsp\\;
I can tell there is still oil residue on the wires down there though, probably from previous changes and I just never noticed. I think later this week I will take the cover off and spray everything down there real good, and perhaps the rest of the engine. It's so black it looks wet. Amazing stuff.
Old Jun 22, 2008 | 04:07 PM
Dixie Dreg's Avatar
Dixie Dreg
Greased Lightning is wonderful stuff, just don't get it on any aluminum, it will turn it black.
Old Jun 23, 2008 | 01:49 AM
renoa18's Avatar
renoa18
I use a piece of cardboard under the filter but I like the plastic shopping bag
Old Jun 24, 2008 | 02:27 AM
hogx2's Avatar
hogx2
When you put your case of beer in the fridge, cut yourself a piece out of the beer box to slide under the filter.&nbsp\\; Dang, I need to change oil again!!
