Hey guys. Second post. Love the site. I have an 07 Heritage Springer. I just bought the 14" Gimp bars (still waiting for them to ship, ordered 4 weeks ago).Can anyone help with the length I need on the cables. Im using stock riser. \\;Also if anyone has them on there ride, how do you like them? Any pics? Thanks
Here is what you need if you want \\;coated braided stainless cables.
 \\; Throttle Cable - Barnett Motion Pro Armor Coat #48-772 (+9") $26.95
Idle Cable - Barnett Motion Pro Armor Coat #48-773 (+9") $26.95
Clutch Cable - Barnett Motion Pro Armor Coat #48-663 (+5") $29.95
Front Brake Cable - Russell Coated Stainless #49-421 (50" #3 line with straight chrome ends) $27.95
Master Cylinder Banjo Fitting - Russell #21-220 (12mm 35* male, chrome) $7.95
Caliper Banjo Fitting - Russell #21-218 (10mm 90* male, chrome) $7.95
Other items needed:
(1) Bottle of DOT-5 Brake Fluid (1QT) Trans Oil
(1) Clutch actuator housing gasket located on the right side of the transmission. $3.00
(2) 12mm Banjo Bolt Washers - $.50ea.
(2) 10mm Banjo Bolt Washers - $.50ea.
16 gauge wire to extend the harness plugs unless you want to purchase harness extenders
 \\; AO
