Bleeding front brake and brake fluid
Old Jul 13, 2008 | 09:17 AM
128auto's Avatar
128auto
Default RE: Bleeding front brake and brake fluid
I would use mighty vac to suck everything out, put Dot 5 in the reservoir and flush it at least 2 reservoirs capicity, you should be able to get rid of all the Dot 4.
Old Jul 13, 2008 | 03:00 PM
Other Sheep's Avatar
Other Sheep
You should be changing the brake fluid every two years any way. Mixing 4 and 5 is not a good idea. Make sure you get all the 4 out.
Old Jul 13, 2008 | 04:04 PM
WARG's Avatar
WARG
Picked up the mity vac today. I will bleed the brakes later this week and switch out the master cylinder.&nbsp\\; Thanks everyone.
biketroll
Jun 2, 2021 11:00 AM
lateralus
May 27, 2013 06:34 AM
neverdown
Wheels/Tires
Jun 5, 2009 09:57 PM
braggster
May 20, 2007 10:51 AM
phreak
Mar 28, 2006 01:49 PM
