Bleeding Brakes, help...
Old Jul 20, 2008 | 10:02 PM
WARG's Avatar
WARG
Default Bleeding Brakes, help...
Installed my chrome controls today, but when I was bleeding brakes&nbsp\\;I couldn't get&nbsp\\;it back to the same firmness as before.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; Used the mityvac pump to get all the air out, and the brakes work, but the brake lever is not as firm as before. Any hints?
&nbsp\\;
I also put teflon tape around the bleeder screw threads just to make sure no air was entering the line.&nbsp\\;
Old Jul 20, 2008 | 10:54 PM
hardhead's Avatar
hardhead
Default RE: Bleeding Brakes, help...
i just squeezed the lever slow and opened the bleeder valve, then closed bleeder valve then let off lever slowly. with a friends help of course. after many rounds of that and adding fluid i eventually got the firmness i needed. personally&nbsp\\;th lever squeezes better now than before.
Old Jul 20, 2008 | 11:14 PM
128auto's Avatar
128auto
1. Top up the brake fluid
2. Crack the bleeder screw open
3. Grab the brake lever all the way in slowly
4. Close the bleeder screw
5. Let go the brake lever
6. back to step 2 and repeat until you get a firm grip
Bleeding brake is pain in the S [:@]
Old Jul 21, 2008 | 12:56 AM
Rabbit_'s Avatar
Rabbit_
Do you have dual or single front discs? it makes a difference which side you bleed first if you have dual front disc brakes.
Old Jul 21, 2008 | 01:06 AM
Other Sheep's Avatar
Other Sheep
Same thing happened with my sons 07 Wide Glide. Just had to keep bleeding until it firmed up. Did the squeeze lever loosen bleeder for what seemed like an hour before it got really good.
Old Jul 21, 2008 | 08:42 PM
WARG's Avatar
WARG
single disc.&nbsp\\; I am going to keep at it.&nbsp\\; Won't have time until later in the week.&nbsp\\; Changed master cylinders, but wouldn't think that would matter.
Old Jul 21, 2008 | 09:19 PM
WARG's Avatar
WARG
I just messed with my brake lever some, it feels a little better than I thought.&nbsp\\; Maybe I had too many beers yesterday.&nbsp\\; I'm going to take it for a spin and see how she does.&nbsp\\; Thanks for the help fellas.
Old Jul 22, 2008 | 05:11 AM
dbleagle's Avatar
dbleagle
It is really a pain to bleed the brakes... a lot of patients.... but if you are still getting a little bubble or two when releasing the lever... you still got work to do... tapping the side of the master cylinder helps also.... that little plunger does not move a lot of fluid at a time and the reason it takes so long...
&nbsp\\;
Charlie D...
Old Jul 22, 2008 | 12:37 PM
wallyn's Avatar
wallyn
The dot 5 brake fluid tends to hold a lot of tiny air bubbles. So some say to flick the brake lever a few times to break them up and get them moving. Just keep on bleeding them until it gets right.
Old Jul 22, 2008 | 07:32 PM
WARG's Avatar
WARG
got DOT 4 in mine
01fatty
Aug 29, 2011 10:44 AM
Bedore
Sep 1, 2010 09:17 PM
rkgal
Aug 24, 2009 03:05 PM
MotorSgt
Mar 18, 2009 05:15 PM
Bikerboy50
Oct 2, 2008 08:14 AM
