Exhaust and fuelpak ?
Old Aug 3, 2008 | 04:14 PM
mstng5point0's Avatar
mstng5point0
Default RE: Exhaust and fuelpak ?
I was hopin to save some money by waitin on the intake. But i went and bought the screamin eagle heavy breather intake yesterday and put it all on today. I love the sound of the short shots. Just gotta be more aware of cops lol.
Old Aug 3, 2008 | 06:13 PM
sledgeman44's Avatar
sledgeman44
6th Gear
Getting it on dyna will get ya an extra 3 or so hp but you no longer have to worry about too lean or rich and overheating has been a problem on the 96 cu. in. when its too lean. That's why the factory now requires dyno on warranty when changing intake, exaust and remapping. Get it done right dude it's worth it I had all kinds of problems with a Dyna-Low-Rider cause it wasn't right.It overheated caused leaks on heads all that good s___.
Only my opinion but I thought it was worth it on my FXSTC and have had no problems.
Old Aug 3, 2008 | 10:11 PM
softailjim07's Avatar
softailjim07
&nbsp\\;you will be fine with fuel pack. i have over 5000 miles and it runs great. you will notice a difference from stock.
Old Aug 3, 2008 | 10:13 PM
BluBob's Avatar
BluBob
Sledgemann, are you saying that they dyno-tuned a bike with a fuel pak?
SoftailJim, what modes did they tell you to adjust, and what values did they give you?
Old Aug 4, 2008 | 01:01 AM
Panky's Avatar
Panky
&nbsp\\;
I read in American Iron that if you put on screamin eagle slip ons and a stage1 air cleaner the 07 can over come a small change but you have to get a pc111 or a tuner if you change out the full exhaust?????
&nbsp\\;
What do you guys think
Old Aug 4, 2008 | 01:30 PM
sledgeman44
6th Gear
96" w/SE air cleaner, V&amp\\;\\\\\\;H Big Radius, &amp\\;\\\\\\; SE-EFI Race Tuner&nbsp\\;\\\\\\; Have not looked at tuner specs or settings yet. Max Power+70.51 Max Torque 83.29. Gained 7hp over stock settings on power band top end. Fuel mix around 13.5 around bottom end stock changed to&nbsp\\;12.6 (a little lean). Top end&nbsp\\; 13.5 stock to about 12.2.
Old Aug 4, 2008 | 03:49 PM
SAS's Avatar
SAS
ORIGINAL: sledgeman44
96" w/SE air cleaner, V&amp\\;\\\\\\;\\\\\\\\\\\\\\;H Big Radius, &amp\\;\\\\\\;\\\\\\\\\\\\\\; SE-EFI Race Tuner&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; Have not looked at tuner specs or settings yet. Max Power+70.51 Max Torque 83.29. Gained 7hp over stock settings on power band top end. Fuel mix around 13.5 around bottom end stock changed to&nbsp\\;\\\\\\;12.6 (a little lean). Top end&nbsp\\;\\\\\\; 13.5 stock to about 12.2.
&nbsp\\;
I think that you have it backwards. 12.6 and 12.2 are rich not lean. 13.5 is the preferred F/A ratio, Stock is 14.6
Old Aug 4, 2008 | 06:23 PM
softailjim07
blubob, cell 1 and&nbsp\\;2 for just off idle. they told me to put cell 1 to +5 from 0, and cell 2 to +4 from 0. i have them at 4 and 3 right now it seems to be pretty good.
Old Aug 4, 2008 | 06:26 PM
softailjim07
sas, i think it air to fuel ratio, so it would 14.7:1 which is 14.7 parts of air to 1 part fuel. if i had a ratio of 12:1 i now have a rich mixture because i have less air.
Old Aug 5, 2008 | 07:23 AM
SAS's Avatar
SAS
ORIGINAL: softailjim07
&nbsp\\;
No kidding. He was saying that 12.6 was (a little lean) and 13.5 was stock which it is not.
