Which Poly Riser Bushings?
Old Aug 22, 2008 | 10:47 AM
Nostalgic07's Avatar
Nostalgic07
HD poly bushings worked fine for me...but sounds like you got them a-lot cheaper...should work out fine for you!!
Old Aug 22, 2008 | 12:30 PM
JRK5892's Avatar
JRK5892
not sure if you need it but here is a how to on replacement from my bob:
https://www.hdforums.com/forum/dyna-glide-models/263272-riser-bushing-how-to.html
Old Aug 22, 2008 | 01:20 PM
WARG's Avatar
WARG
Thanks again guys, Citoriplus, as always you are a wealth of information.
JRK5892, that is the best looking Street Bob I've seen. The color and wheels look sharp.
Any reccomendations on installing the bushings without removing the fork tins on my fatboy. Removing the tins will require removing the turnsignals on the front and that is just a pain.
Old Aug 22, 2008 | 03:21 PM
JRK5892's Avatar
JRK5892
if you can access behind them you should be fine, i know my dads heritage has access plates that can be removed on the back with 3 or 4 screws and then i use ratcheting wrenches to tighten his bars and what not... should be the same for you... the last fatboy i built for my uncle we removed the fork covers, sorry i am not much help... thanks for the props on my bike!
odog422
Aug 18, 2017 02:44 PM
plongson
Touring Parts
Nov 30, 2016 06:27 AM
Celphish
Dec 29, 2015 07:11 PM
Fat Boy Slim
Dec 25, 2010 12:02 AM
JRK5892
Jun 20, 2008 03:11 PM
