Just got my first bike, it's a 1994 custom fatboy.
When the bike is put into gear ,I can't get it back into neutral unless I turn the bike off and it slips right back in without any problem.
Anyone have any ideas on how to fix this problem?
I would check to see if your clutch adjustment is correct, if it's not fully dis-engaging it will cause the trans input shaft to spin at a rate that won't allow you to shift into neutral. Turning off the engine of course stops this. It may just need a minor adjustment. Good luck!
It's an easy install, but you do have to drain the primary so you can pull the main cover. For insurance against leaks, you should probably use a new main cover gasket. So far I've had good luck reusing the smaller gaskets. Though the front one gets a little fuzzy after a few times on and off, it hasn't leaked yet. The "derby" gasket has a rubber bead on it and so is a bit more robust...
