help installing 3" Arlen Ness forward controls
Old Oct 13, 2008 | 03:59 PM
YZWILLY's Avatar
YZWILLY
6th Gear
Default help installing 3" Arlen Ness forward controls
I installed the shifter side with ease maybe 5 mins. Now I am getting ready to install the brake side. I can't quite firgure out what the instructions want me to take apart. Please anyone who has done this conversion, if you have used a thread from this site,please turn me on. thanks. Also master cylinder says use only dot4 and all I have is dot3 , so should I follow the directions or doesn't it matter. Thanks
Old Oct 13, 2008 | 04:42 PM
hardhead's Avatar
hardhead
i could be wrong but i wouldnt mix the two brake fluids. they sell dot4 at walmart for like 3 bucks. thats what i used, and haven't had any issues.
Old Oct 13, 2008 | 05:22 PM
SuperUnknown's Avatar
SuperUnknown
DOT #3 and #4 will mix...only diff is #4 has a higher boiling point...I've used a blend of #3 and #4 in my rear master cylinder for a few thousand miles now...no problems.I installed the Ness 3" forwards on my '06 Softail and had no real problems with either side...they bolt on pretty much the same way...you'll have to swap out the brake line (which is included with the AN forward kit) but other than that I didn't have to disassemble anything...what exactly are you having trouble with??
Old Oct 13, 2008 | 05:34 PM
YZWILLY's Avatar
YZWILLY
6th Gear
Default fixed
I sat down and calmly opened a beer, called AN tech assist. Guess what they sent me an old bracket w/ new instructions. The tech guy walked me through it. Se that beer fixes everything. Thanks again guys he also told me to stay w/ Dot 4 don't mix or change is what he said.
Old Oct 13, 2008 | 06:33 PM
07FXSTC's Avatar
07FXSTC
Now what fun is that...you went and called an expert.
Dtown
Jul 7, 2017 07:00 AM
maverick0011
Aug 13, 2011 04:18 PM
EvilWayz
Ironhead
Dec 6, 2009 03:25 PM
mfred_2000
Apr 3, 2008 06:25 AM
Softtail Bob
Mar 23, 2006 11:18 AM
