Potato, potato...
Old Apr 2, 2006 | 07:16 AM
Nasty350LT1's Avatar
Nasty350LT1
Default Potato, potato...
Everyone like the low idle or "Potato, Potato" sound our bikes make.
While my bike was being serviced the other day the Harley Technician,
said my idle was too low. It was set aaround 750 or so.
He said that's no good for the bottom end. So he raised it to 900 - 1100
What's your idle set to ? Mine seems way too high now...
Old Apr 2, 2006 | 08:28 AM
TexasFatboy's Avatar
TexasFatboy
Default RE: Potato, potato...
It's true...The twin-cam is supposed to be set somwehere around 900-1100 for the oil pressure.
Edit:
Oops.....just realized your running an EVO, I have no idea about the idle on those, my bad.
Old Apr 2, 2006 | 11:11 AM
springerGT's Avatar
springerGT
They idle mine up when I take it in also.
Old Apr 2, 2006 | 12:16 PM
chopperchuck's Avatar
chopperchuck
set the idle to where you want it.. ive been running mine so low the bike will barely run for years..........it wont hurt anything
Old Apr 3, 2006 | 11:32 AM
95BadBoy's Avatar
95BadBoy
Manual says 1000 rpm's. I have mine set there. evo's need oil
Old Apr 3, 2006 | 11:30 PM
Nasty350LT1
Heck, it idles so fast, when I go to make a cold start up,
I won't even need to pull out the choke...
Old Apr 4, 2006 | 04:20 AM
FXST's Avatar
FXST
ORIGINAL: 95BadBoy
Spot on. Evo's need to idle quicker more so then the twin cam. Idle an Evo to slow and you will have very minimum oil flow....
Old Apr 4, 2006 | 11:06 AM
dert's Avatar
dert
Correct..Mine is at 900.Evo,s shouldnt idle too long either..Parades,mines never seen .Not enough oil flow.I usually fire mine up and take right off .Cold weather or hot.
Old Apr 4, 2006 | 12:08 PM
89FLHT's Avatar
89FLHT
Both my Evo's idle at 1000. No need to beat the **** out of the bottom end bearings and reduce the oil flow just to get the sound.
Old Apr 4, 2006 | 09:11 PM
pococj's Avatar
pococj
Too low an idle = too little oil, especially on the bottom end. Great way to make square bearings.
flyboyron
Nov 21, 2013 04:22 AM
modular
May 31, 2012 07:49 AM
HighLiner
Dec 1, 2011 02:10 PM
jorswift
Jun 3, 2009 06:10 PM
Booey424
May 26, 2007 12:57 AM
