Foot Peg Tricks
Old Nov 12, 2008 | 12:12 PM
BoneCrusher's Avatar
BoneCrusher
I got the nut and bolt replacement for the OEM cotter pin setup and tightened those ****'s down nice and hard and it fixed mine.
Old Nov 12, 2008 | 01:02 PM
jknowlton's Avatar
jknowlton
i got shims..still does it on one peg...will rebend them again.
Old Nov 12, 2008 | 01:45 PM
Hrd Rider's Avatar
Hrd Rider
Default Peg Tricks
Your new pegs should be the same width as your stock pegs since they are Harley Pegs. Take your Spring Steel Tension Spacers out and take a pair pliers, insert the ends of the spacers into jaws of pliers and bend slightly to give them more tension. If you try putting 2 spacers in they will not fit. If that doesn't work you can always buy new ones, they are the least expensive items that Harley sells. Good Luck.
Old Nov 12, 2008 | 05:59 PM
tk353's Avatar
tk353
My stock shims were in backwards, I bought 2 new ones for about $1
Old Nov 12, 2008 | 07:13 PM
nowbmw's Avatar
nowbmw
Thanks for all the responses, i gotta go to the dealer, i will grab a couple shims, thanks
izhd
Sep 27, 2014 07:45 AM
sprnt96
May 31, 2014 03:55 PM
SCPowerstrokecowgirl
Mar 28, 2013 11:31 AM
HighGlide
Jul 15, 2012 12:34 AM
1flhtk4me
Oct 2, 2010 08:18 AM
