Drilling and Tapping Help?
Old Dec 15, 2008 | 11:45 PM
Dagerazod's Avatar
Dagerazod
Originally Posted by m i k e
bad cop no donut here
pissing up a rope eh?
Southern coloquialism for an excercise in futility
Old Dec 16, 2008 | 12:23 PM
Rail's Avatar
Rail
Some of your replies just baffle me Mike..
Like the other have said, you need to build up the points where you will be tapping the tank.. You can drill and tap .100 thick stuff but it won't hold for more than a screw.. In order to mount hyd/oil lines you need to have bungs welded onto the tank where you plan to mount the oil lines.. Then they need to be drilled.. You can tap just the bungs or install helicoils.. Because aluminum is so soft and sooner or later you will hit one of the lines, I would probably go with the helicoils so you don't strip the threads in the aluminum.. And as others have said, the best way to weld al is with a tig welder... They're pretty expensive so you won't find them at just any shop unless they do a lot of stainless or aluminum fab work..
Bottom line.. You aren't gonna fab this tank at your house based on your responses to this point..
Old Dec 16, 2008 | 12:40 PM
Dagerazod's Avatar
Dagerazod
Yeah... I managed to put that much together. I suppose I was hoping someone would say.. Yeah! Drill it... tap it... screw in a fitting and you are golden! Alas... not so much. heh
Someone offered to help... but with shipping to them, paying for the fab, and shipping return... probably easier taking it to a local shop.
I think I found a guy this morning. Yay!
My New Years resolution is to learn to weld.
Easier than loosing this spare tire I always claim on Jan 1.
Old Dec 16, 2008 | 12:58 PM
Rail's Avatar
Rail
LOL... Maybe not.. Anyone can stick or mig weld steel.. It takes time and skilz to tig al or stainless... A high dollar doesn't hurt either... lol.. Good luck
Old Dec 16, 2008 | 04:55 PM
powaypete's Avatar
powaypete
Try using a bulkhead mounted MS or AN fitting with an o ring and teflon backup ring. Why do you find these? Got a small airport around? These parts are for aircraft and I'm pretty sure the guys there will explain how to drill and mount. No tap required. Just have to match up the fitting on the oil lines to match the tank.
Hot rodders have been doing this for years.
Old Dec 16, 2008 | 07:18 PM
blackjack66's Avatar
blackjack66
2nd Gear
oil tank require that the return and breather lines either come in from the top or have standpipes to prevent back feeding. Also you're likely to want NPT threads, these require that you ream the hole with a tapered reamer, as they are tapered threads. I have sucessfully tapped straight holes for pipe thread before, but it's very hard to do nicely. Also, you will want at least about 3/8" of meat for good threads. Why not have the welding done at a welding shop, and then drill and tap yourself?
Old Dec 16, 2008 | 08:37 PM
m i k e's Avatar
m i k e
[QUOTE=Rail;4241950]Some of your replies just baffle me Mike..
must be all the nyquil im taking
green death flavor of course
haven't been myself sorry.......:sirs
Old Dec 17, 2008 | 02:08 AM
5speedblu's Avatar
5speedblu
Don’t forget the fancy mount because when you vibrate it the mount or the metal will break.
shaking aluminum very fast while trying to hold it still, well not a good thing
(See my post on tinsel strength & atoms)
Old Dec 17, 2008 | 06:54 AM
boosteddelslow's Avatar
boosteddelslow
The only easy way to do this with limited tools and skill is to use bulkhead fittings. I think they would be your best bet if you really want to use the tank you have.
magnum629c
Apr 11, 2020 11:50 AM
Yevick
Oil Archive (no new posts)
11
Nov 4, 2017 09:51 AM
800screws
EVO
14
Dec 20, 2014 01:48 PM
123easypay
Engine Mechanical Topics
May 8, 2011 01:47 AM
scooter34
Mar 31, 2009 08:09 AM
