Help... unseat a star socket
Old Dec 23, 2008 | 01:32 PM
P'colaHarley-17RGS's Avatar
P'colaHarley-17RGS
Default Help... unseat a star socket
Possibly stripped a star socket and now I'm having trouble with the proper
star wrench unseating the dawgone thing...
Any ideas?
Old Dec 23, 2008 | 01:36 PM
jason628's Avatar
jason628
Greetings,
You can try just a regular allen wrench similar size...Might be able to get something to grab that way.
Old Dec 23, 2008 | 02:04 PM
P'colaHarley-17RGS
looks like I'm going to have to go and buy some easyouts... thanks.
Old Dec 23, 2008 | 02:52 PM
chrome-dome-dave's Avatar
chrome-dome-dave
If you have a air hammer with the straight bit you can go straight down on it to make a divet then **** the air hammer at an angle and break the bolt loose.
Old Dec 23, 2008 | 02:59 PM
SIXR's Avatar
SIXR
Just grip the head with a pair of Vicegrips or even Channelocks and try to loosen
Old Dec 23, 2008 | 04:56 PM
buckskin's Avatar
buckskin
Or,...you can cut a straight slot into the head by using a dremmel tool. Then using a suitable straight edge say screwdriver or ratchet with straight socket gently turn counterclockwise.
Should do the trick, remember to gently tap the head with a hammer to get it loose somewhat.
Old Dec 23, 2008 | 05:46 PM
Dagerazod's Avatar
Dagerazod
My fender set came in today and I was about to tackle it when on star bolt one of the fender struts I felt it rip the metal a little.... I stopped... went through the tool box and found a flathead that would fit.... slapped it into a vise and bent it at a 90 degree angle... then slipped a couple feet of pipe over the handle for a cheater bar.... ZIP! came right out!
I will be undertaking two tasks in the morning...
1. Locating the perfect fit star tool for these damned things
2. Locating REPLACEMENTS FOR THESE FRIGGING THINGS WITH A SAE HEAD!
Old Dec 23, 2008 | 05:51 PM
ranger56528's Avatar
ranger56528
Every tool box should have a good Torx bit set,10,15,20,25,27,30,35 then you will never have to worry...
Old Dec 23, 2008 | 06:09 PM
DaddyKnuck's Avatar
DaddyKnuck
Harley chose a steel with the hardness of fine Swiss chocolate for its Torx hardware. Personally I like the "cut a notch and drive it around with a punch technique", but there are many that work as well.
Several years ago I bought bags of polished stainless hardware in the various common sizes. About $50 total and now one fo the first tasks with a new bike is to toss the Torx hardware into the weeds.
Old Dec 23, 2008 | 06:34 PM
Blk and Chrome's Avatar
Blk and Chrome
most times you strip a torx out you are useing the wrong size. Most times it is between a 40 and 45, a 25 and 27 . I deal with them on a daily basis. Also get quality tools, cheap tools strip bolts
