got a new deuce QUESTIONS????
Old 12-31-2008, 03:57 PM
chinexican's Avatar
chinexican
chinexican is offline
Default got a new deuce QUESTIONS????
so I picked up a deuce from my pops last week for a steal!! I hate it! I normally ride a evo rigid chop. I have some questions and maybe you can help.
The Deuce tank is to long! does a normal softtail tank mount the same?
how low can you lower that sucker? What makes it so different than other softails?
Old 12-31-2008, 04:59 PM
sonar_chris's Avatar
sonar_chris
sonar_chris is offline
The tank mounts in the same way all the softail tanks mount, but the rear mount is further back. Lowering your bike to a max of about 2". Depending on your weight, if you ride 2 up, any further than that and you will bottom out a lot. What makes the Duce unique is the stretched tank and rear fender, other than that its a Softail. There are a lot of Duce specific parts though, and interchangeability between other softails is sometimes hard.
Old 12-31-2008, 05:12 PM
snakeinthegrass's Avatar
snakeinthegrass
snakeinthegrass is offline
Don't forget all the chrome that came standard. My 2004 Deuce was over $17,000 before taxes and mod's. That is an expensive Harley considering it is a softy. My personal opinion: Well worth the money or money well spent.
Old 12-31-2008, 07:06 PM
57RebelRocker's Avatar
57RebelRocker
57RebelRocker is offline
+1 with what sonar chris said
Old 12-31-2008, 07:16 PM
conroskie's Avatar
conroskie
conroskie is offline
If you got her for a steal I'd learn to like it IMHO. You might need to lower it though, I know this realy helped on a buds bike. And they do have a lot of chrome.
Old 01-01-2009, 11:04 AM
chopper blue deuce's Avatar
chopper blue deuce
chopper blue deuce is offline
You can use a softail tank on a deuce, but you have to remove the extention bracket on the frame, change the console, and seat as well.
Old 01-01-2009, 12:55 PM
wiseguy2day's Avatar
wiseguy2day
wiseguy2day is offline
Isn't the rake on a deuce 5 degrees more than a standard? The front fender is mounted differently as well and the lowers are different.
Old 01-01-2009, 02:10 PM
Called2Duty's Avatar
Called2Duty
Called2Duty is offline
Default deuce response
they were made from 00 to 07 the 07 came lowered 1 1/2 from the factory, with extended controls and the 96 cubes with 6 clogs, I have a 07 with V and H BR's and 204 cams. i bought it knew and have since thought about changing to a fat bob tank myself,, feels like a sporty when u ride it tank is to narrow. also good luck when looking for add on get used to (except FXSTD) Kurikayn or however its spelled makes a ton load of goodies for the deuce. I do get a lot of compliments on it but I still wish i had got the night train instead, oh well a lot of folks would love to have what you got for steal so enjoy bro.
Old 01-01-2009, 04:14 PM
chinexican's Avatar
chinexican
i've decided to look for a 23" front if they make it, for the deuce. slamm it 2" all the way around and powdercoat everything.
Old 01-01-2009, 04:16 PM
chinexican's Avatar
chinexican
Default pic
here it is
Quick Reply: got a new deuce QUESTIONS????
