Numb Hands.........
Old Apr 13, 2006 | 04:47 AM
Alien Spyder's Avatar
Alien Spyder
Default Numb Hands.........
I'm sure this topic has been discussed here before. I did a search for vibration and I came up with a lot of threads but most of them heve been deleted. I'm new around here so bear with me a bit.
I have an 03 Night Train and the handelbar vibration has finally gotten to the point where I'm installing some ISO grips. Inside the handel bar I'm going to install some pretty heavy pieces of pipe. The pipe is along the lines of the "roll of nickles" trick that has been used by Sporster rider for years. The pipe I have is a tighter fit than nickles.
Hopefully this will fix the vibration problem. The bikes been checked out at two dealers. There is not a mechanical problem. All they say is "should have bought a Dyna".
I can't go through another riding season with this problem. I took a 50 mile ride today. I got off the bike at 5:PM. It's now 2:30 in the morning and my hands are still a little numb.
I checked out the bar snake and the little weight inserts that are for sale but I think the home made pipe inserts should do it.
I'm gonna do this mod Sunday night.
Does anybody have any last minute suggestions or input?
When all is said and done I'll post the results of my experiment![sm=ts.gif]
Old Apr 13, 2006 | 04:54 AM
ICE17N24's Avatar
ICE17N24
Default RE: Numb Hands.........
Don't have any suggestions for you just one quick ?
Do you have the stock drag bars on it?
Old Apr 13, 2006 | 05:07 AM
Alien Spyder
No, pretty much right from the get go I got rid of the stock drag bars. They looked cool but it was uncomfortible as Hell!
Old Apr 13, 2006 | 05:24 AM
ICE17N24's Avatar
ICE17N24
Same here, put the street slammers on. I don't know Bro, my Train doesn't vibrate half the amount of my wife's Street Bob. Let us know how it turns out and I might do that to the wife's Dyna if it works.
Good luck and ride safe
Old Apr 13, 2006 | 05:44 AM
darkside's Avatar
darkside
If you don't have internal wires in the bars and don't plan on it I have heard of guys filling the bars with clear silicone.The said it helped alot.
Old Apr 13, 2006 | 08:27 AM
Ronbo's Avatar
Ronbo
I had the problem with my hands too, with the stock bars. I installed pull backs. Thant took care of my problem.
Old Apr 13, 2006 | 08:55 AM
93HD's Avatar
93HD
try getting a quality bar 1 1/4" chubbys or carlini or ape hangers.good luck!
Old Apr 13, 2006 | 05:37 PM
RiggidyRaw's Avatar
RiggidyRaw
I just road in to work today on my fatty and my right hand/arm was numb. I was debating on what my next upgrade would be, but after today I know what it's going to be.
Old Apr 13, 2006 | 07:00 PM
Babs's Avatar
Babs
The stock fatboy bars put your arms at a stretch.. If they're straight out with no relaxed bend, it inhibits good blood flow. I had a huge problem going numb until I went to heritage bars, which are narrower, taller and more pulled back for easier reach. Problem solved. I never could get the reasoning behind their design of the stock FLSTF bars.. my humble opinion, they're aweful.
Old Apr 16, 2006 | 01:14 AM
Alien Spyder
OK, here's the deal.
I removed my stock grips. Then I installed two 1" pieces of stainless steel pipe, 6 inches long inside of the handlebar to give the bars more weight. (one pipe under each grip)
I then installed new Kuryakyn Iso-Grips with the throttle boss.
I just took the bike for a 12 mile ride for the first time without gloves. There was no vibration. Zero!
I don't know if it's because of the Iso-Grips or because of the weights I installed or both but I'm one happy camper!
[sm=wootwoot.gif]
