changing levers
Old Jan 4, 2009 | 05:50 PM
kingforce's Avatar
kingforce
Default changing levers
In am going to change out my stock levers (clutch and front brake) on my 02 Fatboy for some new chrome ones...I do have a shop manual, but is there any tricks or tips i should know before attempting this? I am concerned about changing the front brake lever!!
Old Jan 4, 2009 | 05:52 PM
JayStronghawk's Avatar
JayStronghawk
Can't swear on an 02 but on my 04 Heritage was just a matter of taking off the snap rings below the Levers and replacing them back .. didn't have to touch any adjustments ..
Old Jan 4, 2009 | 05:57 PM
kingforce's Avatar
kingforce
Will the piston fall out or loose any fluid?
Old Jan 4, 2009 | 07:10 PM
57RebelRocker's Avatar
57RebelRocker
changed levers many times...and no..the piston won't fall out...the whole swap out should take you 5 minutes tops if that
Old Jan 4, 2009 | 08:11 PM
kingforce's Avatar
kingforce
Smile
Thanks for the info guys....
Old Jan 4, 2009 | 08:14 PM
Kbore's Avatar
Kbore
While you're out, get a couple of extra snap rings ...
Old Jan 4, 2009 | 08:45 PM
wildman67's Avatar
wildman67
+1 just remove the snap ring's.
Old Jan 5, 2009 | 12:50 AM
Djstorm100's Avatar
Djstorm100
I was told to put some cardboard or something to hold the brake switch back...and if I didnt I would break it?? any truth to this? I can turn a wrench on a car, hell I build cars from the ground up. But never really wrenched on my bike before.
Old Jan 5, 2009 | 07:37 AM
hogwash's Avatar
hogwash
I never use anything. Just be aware of it and really careful with the front brake switch.
Old Jan 10, 2009 | 06:29 PM
Kbore's Avatar
Kbore
Dont take 10 seconds to put a piece of cardboard in and SEE if the level breaks the switch....
