will these fit my 09 crossbones?
Old Feb 12, 2009 | 05:40 PM
roostracing's Avatar
roostracing
Default will these fit my 09 crossbones?
Softail 1984-06, 96"+ engine straight cut in black ceramic...hooker pipes...part# 27400-1DHKR...or 441-207...pg 171 in the 2008 J&P cycles catalog....top right corner...i want them in black though...the picture shows them on a chopper but look sharp...i dont know if it will clear the rear passenger pegs...
Old Feb 12, 2009 | 05:47 PM
raaaaaa's Avatar
raaaaaa
a pic helps
Old Feb 12, 2009 | 06:41 PM
crazybastid83's Avatar
crazybastid83
Check out pipes here they are cheap as hell:
http://www.hookerpipes.com/category_s/27.htm
crazybastid83
You need an 07 up pipe unless you are going to eliminate the 02 sensors (using a power commander)
Old Feb 13, 2009 | 07:51 AM
roostracing
sorry guys...i put the picture but i guess it didnt work..must of have done something wrong when uploading...but yeah that hooker website link is correct...its the first pic on the link... http://www.hookerpipes.com/category_s/27.htm
Hooker has everything 75% off!!!! Now is a good time to buy hookers if anyone is looking! I wonder why...going out of business?
Old Feb 13, 2009 | 08:24 AM
DaddyKnuck's Avatar
DaddyKnuck
All softails use the same two bolt flange so they can be made to work. As previously noted, unless you are looking to eliminate the o2 sensors you will need late model pipes, or you will need to put the bungs in. Bungs are about $3 each and can be purchased at any muffler shop. They will also cut and weld them for you if you don't weld. Because they are on the back side of the pipe you don't need beautiful welds either.
My '03 has pipes from an Evo Softail. Just had to make brackets. A little 1/8" steel and some hammer engineering. My '08 Crossbones has pipes from a '02-'06 TC, but welding in o2 bungs and painting saved big dollars. The upsweeps were $40 on ebay, the Snub Nose were $50. A little work and hundreds saved.
CamSG09
Feb 24, 2016 06:25 PM
scooter_trash_1
Nov 4, 2010 04:06 PM
edehn
Exhaust System Topics
Jul 29, 2009 09:26 AM
modes
Jan 4, 2009 06:00 PM
masterblaster
Aug 26, 2008 05:00 PM
